Wheel locking driving at top speed. - Defender Source
Old October 27th, 2003, 11:40 AM
MattD
Matt Dillon
Defender 90 1990
Unhappy Wheel locking driving at top speed.
While on the motorway, my defender 90, locks up and all of a sudden I become a rally driver :o)
It seems something? on the front driverside viciously locked. The diff is fine, the brakepads healthy and not broken up, no wheel wobble ( like if a bearing has gone)
Still I dont know what it may be. The brakes didnt get hot and lock and there was no warning, just instant lock and rubber smoke.
There is a grinding noise as I tried to "creep" home along the hard-shoulder, another time feeling like it was going to bite and lock. So I got towed. Still drives, still everything moves ok.
Drive shaft maybe? Can they lock up?
Anyone offer me some advice?
Matt
Old October 27th, 2003, 03:57 PM
If it just the front I would guess that something in the diff broke and is getting stuck in the teeth. Maybe a tooth broke off and when the fluid in the diff gets moving around it gets pulled into the teeth. Try draining the diff fluid and check it for metal.
Old October 31st, 2003, 01:51 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Does this happen a lot or was it a one off?
I'd check the wheel bearings. Disassemble not just try and wobble the wheel.
The bearing may well have siezed and now be rotating on the stub axle. This is not a good thing to be happening.
I think that if it was something in the diff locking the diff would have exited through the front diff pan in a rather loud, expensive and exciting manor in rather more pieces than Land Rover intended.
I wouldn't recomend driving at any speed at all until you find out what's up.
Mike Hammond
Old October 31st, 2003, 06:53 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
I'd call it a blown bearing as well. Pull the hub off and look at the outer ones first. Could be inner as well.
Old November 1st, 2003, 03:46 AM
mikeslandrover
Mike Hammond
The wheel bearings usually last for ever if there the older style hubs which are oil fed from the axle. trouble seemed to start when LR decided to use grease. A friend of mine has had two bearings sieze on his TD5, similar thing couple of warning squeeks and then the wheel locks solid.
Sometimes they free up after the inner wheel bearing has friction welded it's self to the stub axle.
Mike Hammond
Old November 1st, 2003, 01:42 PM
MattD
Matt Dillon
Defender 90 1990
I was thinking, it CANT be a wheel bearing.. but last monday I had it all apart and sure enough, a bag of bolts inside the hub. I just never known one lock, let alone so viciously.
Killed the hub AND the stub axle too - Im more p****d that it too a whole load of tread off my week old MT's
Thnx for the replies guys.
Matt
"freedom begins with a game of chance!"
Old November 1st, 2003, 06:36 PM
mikeslandrover
Mike Hammond
Bad news
Still at least noone was hurt. I must check my wheel bearings for water contamination
Mike Hammond
Old February 17th, 2007, 09:17 AM
Antonios
Antonios Hadjigeorgalis
No more
I recently had a similar problem; of course with a slight twist. After sitting for a week in the artic cold blast we are having in the NE, I drove the rover from NYC to Baltimore. About half way there I stop for gas and driving through the rest area the wheels lock and I come to a screeching halt. I try to move forward and it feels as though the parking brake is on, the truck lurches forward but doesn't move. I try reverse and it moves, then goes forward as if nothing had happened. I had a few other instances where it felt like it was about to do it again...only I was moving about 50 mph. SO far it sounds like the issues discussed on this thread.
Now I'm on the highway again and I finally get to my exit and the brake pedal goes to the floor. After a few pumps it's back to normal. But every stop for the last mile home I needed to pump the pedal before getting any brakes.
I'm thinking maybe I have a combination going here, the problem discussed in this thread and another brake issue. Fluid reservoir is still full so there is no loss of brake fluid. How many times do you get two major failures simultaneously? This would be my first time.
Miami, FL
Old February 18th, 2007, 04:04 AM
mikeslandrover
Mike Hammond
Nope, probably just the wheel bearing gone west. The wheel wobbles about and the pads get pushed further back into the caliper than normal and then the first dab on the peddle fails to push the pads far enough out to contact the disc.
Mike Hammond
Old February 18th, 2007, 09:49 AM
Antonios
No more
Thanks. Does anyone know of a source for parts to rebuild the hub? I drove about an hour after this happened so I'm guesiing I'm going to need to rebuild the whole thing.
Miami, FL
Old February 18th, 2007, 08:23 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
that can also happen with a grenaded CV joint. I saw that once and it jammed everything up good
Legend in My Own Mind.
Old February 19th, 2007, 04:48 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
yes as the cv joint falls apart it can lock the wheels up real bad
Old February 19th, 2007, 04:54 PM
mikeslandrover
Mike Hammond
You may just get away with wheel bearings if the bearing race hasn't friction welded itself to the stub axle even if it has you can sometimes cut the race off and clean up the stub axle and reuse it. If it's th CV joint then they're not repairable in any way, shape or form
Mike Hammond
vin, wheel
Brand New Set of 5 Locking Wheel Nuts kpracer For Sale - Parts 2 December 23rd, 2004 07:29 AM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
land rover OEM locking wheel lugs mpodgorski For Sale - Parts 2 December 29th, 2003 12:22 PM
