wheel lock key help?? - Defender Source
Old October 5th, 2015, 11:27 AM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I went in for a tire rotation and after the "mechanics" were done. I noticed about 1/4 inch of water in both cupholders. Figured they spilled something so went home and parked the truck. A few days later went to move the truck and found that they also lost one of the plastic center caps on the front passenger wheel and broke a prong off the wheel lock key thingy.
The question is how do I fix this missing prong. I still need to check and see if it is stuck in one of the wheel locks, but is it totally necessary to have all four prongs??
wheel
1997 d90 soft-top door lock key swap d90boy Defender Technical Discussions 9 February 14th, 2012 04:49 PM
Door lock key blank gliebig Wanted 1 May 20th, 2010 03:58 PM
How do I remove a lock cylinder if I don't have the key? evilfij Defender Technical Discussions 5 May 1st, 2009 01:45 PM
Ignition switch key lock revtor Defender Technical Discussions 5 December 4th, 2006 06:32 PM
