Wheel Bearings - Defender Source
Old November 10th, 2012, 06:50 PM
andy110
Andy Bard
1986 110 CSW
Wheel Bearings
Just put new CV joints and and swivel balls in my 1986 110. Having a big problem with the wheel bearings that came in the Rovers North hub rebuild kit. The Timken bearings that came in the kit NP449291 do not fit on the stub axles! They are too tight, I thought it might be the new stub axles I installed, but they do not fit the original stub axles either. I have emailed Rovers North about this, anyone else have this problem???
Old November 10th, 2012, 07:00 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I just used the timken set37 on my '86, so those should work for you and they're available at most auto parts shops. If you're coming up this way by chance I have a set on the shelf you're welcome to have and see if they work.
Old November 10th, 2012, 07:36 PM
andy110
Andy Bard
1986 110 CSW
Thanks Tony, I'll just drop by the parts store tomorrow.
Old November 10th, 2012, 07:51 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I couldn't find the listing for the seat base clips (likely due to a poor search string) but you might try britcar or LrSeries, both seem to stick small parts.
wheel
wheel bearings and seals Uncle Douglas Defender Technical Discussions 8 August 20th, 2010 08:18 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
