Wheel Bearing Upgrades - Defender Source
Old June 6th, 2016, 03:39 PM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Have been noticing some squealing while driving around for the past few weeks, and then noticed one of the back hubs leaking. Now I know my rear axle where swapped for a disco with disc brake conversion and not a hundred percent sure on the front yet, but is there any recommended upgrades I should consider while I'm getting involved replacing the bearings?
Old June 7th, 2016, 12:09 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
With the rear squealing, you may need to replace the axle spindle end too.
Your Disco1 axle will have 2 seals on each axle end, a small one (inner) and a larger exterior one. The larger one is available in a double lip version, that's the one to replace it with.
The small one is to keep the diff oil out of the bearings and the large one is to keep the bearing grease in the hub.
Some guys only run the outer seal (large Dbl. lip) and allow the diff oil to lube the bearings in the hub (2 sets of bearings).
Old June 9th, 2016, 11:05 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Awesome.. Thanks for the info
Wheel bearing/stub axle nuts tomaco1 Defender Technical Discussions 17 January 30th, 2011 03:02 AM
stuck wheel bearing sflash868 Defender Technical Discussions 12 September 2nd, 2009 10:05 AM
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
Rear wheel bearing damage potential?? Neo Defender Technical Discussions 8 November 28th, 2004 11:58 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
