Wheel balancing problems alloys - Defender Source
Old April 17th, 2016, 06:39 PM
Ben01
Ben
Defender
I've tried two shops and neither can balance my sawtooth wheels..all four weels are asking for too much weight. The wheels are supposed to be OEM, but it is possible they are not...that being said...I doubt all four wheels are defective! Thoughts? Anyone have a similar problem?
Old April 17th, 2016, 06:47 PM
Most LR wheels are lug-centric, not-hubcentric. They may need to use an adapter to balance them.
-Jeff
What alloy Land Rover wheel is lug centric? I've only ever seen steel wheels that are lug centric, and even then, the wheels are probably still technically hub centric.
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
You need a shop that has a balancing machine called" Hunter GSP9700". Let him run a full test with road force and the machine will specify if you had faulty wheels or tires or if you only need a force matching rotation of tires.
Old April 17th, 2016, 06:49 PM
Hunter makes a few road force balancers...
Old April 17th, 2016, 06:56 PM
Omero's Avatar
Omero
Omar Alomar
Could you please name other model than the GSP9700?
Old April 17th, 2016, 06:58 PM
I'll have to look when I'm at work tomorrow, we have two different ones made by hunter.
Old April 17th, 2016, 06:59 PM
Ben01
Ben
Defender
Will try tonight hopefully, thanks guys...never had the issue with boosts
Old April 17th, 2016, 07:48 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
What tires and size do you have on them? It is unusual that all four would be out.
Land Rover 110
Old April 17th, 2016, 07:56 PM
Ben01
Ben
Defender
265 75 16 tires were previously balanced on boosts
Old April 18th, 2016, 01:17 AM
If the tires balanced before unless they have been damaged or the wheels are junky knock off of the genuine article they should balance.
Where did you get the wheels from? If used I'd suggest getting them checked for out of road potential.
Old April 18th, 2016, 09:11 AM
Ben01
Ben
Defender
I doubt all 4 tires were damaged when removed. Wheels are brand new and I called the store this morning and they assure me the wheels are OEM. I will try again hopefully tomorrow morning.
Old April 18th, 2016, 09:15 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
FWIW, I use high-quality airsoft bb's in mine and they balance out pretty damn well. Works like a charm and no weights to lose on the trail. Cheap too.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old April 26th, 2016, 11:37 AM
Ben01
Ben
Defender
The machine the other shops used is no good. The one tire they "balanced" was completely off. Went to an independent shop this morning and I am good to go now.
Thanks for the help guys.
Old April 30th, 2016, 05:06 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
Simple. Have them put in the bean bags they use for 18 wheelers. They are doing this for a lot of the Jeeps with 35" & 37" tires. I have 305's on my defender and when I switched the tires back to alloy rims with spacers they could not get rid of the death wobble by balancing them. Bean bags did the trick immediately.
alloy, problems, wheel
WTB: 4 x Wheel Spacers for Alloys on 110 ATX_D110 Wanted 4 April 22nd, 2015 12:05 PM
Wheel Center Cap, Used, for Freestyle Alloys SMac Wanted 6 August 13th, 2014 10:49 PM
Wheel nut lock set for alloys Arcadeus Wanted 1 June 26th, 2014 09:58 PM
Tires --> Mounting/Balancing Prices RoverChic Misc. Chit-Chat 17 October 21st, 2005 01:53 PM
265/75/16 tires and factory alloys Rick Carlisle For Sale - Parts 20 February 16th, 2004 11:15 PM
