Wheel Balance, wind resistance or... - Defender Source
Old June 26th, 2014, 08:01 AM
Grover's Avatar
Grover
Question Wheel Balance, wind resistance or...
I noticed vibtration when going 65-70 mph, I rotated the wheels and it made a big improvement. I still have just a "tiddly-bit" of vibtration. I can tell if it's just the wind resistance or something else.
I guess my question is, do you guys experience any vibtration around 65-70mph?
Old June 26th, 2014, 04:25 PM
does the truck sit for an extended amount of time? my tires all have flat spots
Old June 26th, 2014, 04:50 PM
Grover's Avatar
Grover
In the winter it stays parked in my garage. I mark the rims with painters tape indicating the orientation when parked. Every weekend I do start it move it around in my driveway then back into the garage after making sure the tires are not in the same orientation. (Seems overkill doesn't it...)
If I do have flat spots, will they work themselves out?
Anyway, I cringe at the thought of getting them balanced, my boosts are unscathed...
Old June 26th, 2014, 09:20 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Sounds like a harmonic unbalance. (vibration comes in and out at speed) If you rotated the tires and it changed what you are feeling then most probably it is in the tires/wheels. If you feel the vibration from the base of your back then it is from the rear wheels. If has the steering wheel vibrating then it is from the front. Did the vibration change location when you rotated the tires? You can rotate the tires, one at a time, until you find which one is bad. You may have just thrown a weight. The vibration can be coming from another part of the suspension but the tires are the best place to start looking.
Old June 28th, 2014, 01:31 PM
my guess is that the tires are cupped or otherwise strangely worn from being driven while out of balance. my recommendation is to drive it another thousand miles and reasess then.
Old June 28th, 2014, 03:44 PM
Grover's Avatar
Grover
I rotated all of them, putting the spare on the driver side rear and then the passenger side front is now the spare.
Before rotating, I could see the front wings oscillating while driving 65-70
Now, it seems like the rear has a slight vibration...front is ok
Old June 28th, 2014, 08:09 PM
Capt Milks's Avatar
Capt Milks
After rotation and the vibration changed sounds like you isolated the problem. I would look to get the rear tires balanced.
Old June 29th, 2014, 09:52 AM
maybe a duh-huh kinda moment, are all the lugs nuts right and wheels properly mounted
Old July 2nd, 2014, 12:16 PM
Grover's Avatar
Grover
Thumbs up
I had Bob Sumeral rebalance all the wheels and it rides like a new truck!
No vibs at all!
The guy who did the work was AWESOME!
Handled the rims like fine china! You don't find people like that everyday...
Cheers...
wheel
Fuel gauge ohm resistance Brewie212 Defender Technical Discussions 0 February 22nd, 2013 12:47 PM
Feels like an off balance wheel petminded Defender Technical Discussions 8 January 8th, 2013 02:14 PM
Door hinge screws corrosion resistance pmd Defender Technical Discussions 47 February 12th, 2012 12:50 PM
clutch has no resistance Sandt Defender Technical Discussions 4 September 6th, 2011 12:46 PM
new bfg wont balance mattdh Wanted 7 October 27th, 2003 12:25 PM
