whats wrong? - Defender Source
Old May 3rd, 2004, 06:20 PM
jperakis
James Perakis
94 ST
whats wrong?
i was on the freeway today and whenever i hit the accelerator it was as if i had the clutch in. It just reved and reved!!! the only gear that halfway worked was 1st but that only worked up to about 1500 rpm.
I just had my cluth master cylinder replaced so im hoping that it was just faulty repair work.
Is there anything else that it could be?
thanks a lot,
James Perakis
Old May 3rd, 2004, 07:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
sounds like the clutch is slipping. how many miles on the truck and the clutch.. Or a rear mail seal leaking on the clutch.
Legend in My Own Mind.
Old May 3rd, 2004, 08:28 PM
jperakis
James Perakis
94 ST
125K on the truck... and the clutch was replaced last summer in july. so it cant have more then 8-9K on it at the most.
if the clutch is infact slipping what do i do?
remember two things...
Old May 3rd, 2004, 09:06 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
James, can you shift the truck?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 3rd, 2004, 09:23 PM
jperakis
James Perakis
94 ST
yea it shifts no problem, and the clutch feels fine.
Old May 3rd, 2004, 09:28 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Possibly the throwout bearing. The only thing I can guess is the clutch is no longer engaging the flywheel. Might need a new throwout bearing when we swap the tranny, but I bet the new tranny will come with a new one also.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 3rd, 2004, 10:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
just for the hell of it, does it do it when you have the diff locked also?
Old May 4th, 2004, 11:52 PM
Tom Fitzgerald
Tom Fitzgerald
You might make sure the slave rod is adjusted properly. Sounds like it may be too long and doesn't allow the fork to return far enough to allow the pressure plate to fully 'pinch' the disk. Plus it follows the "last part touched" methodology. Worth a look. Good luck.
Tom
Old May 5th, 2004, 01:13 AM
jperakis
James Perakis
94 ST
so miraculously the 90 seems to have fixed itself, for the time being at least. I just fiddled around with the Tcase and everything is now fine ( knock on wood)
but knowing my truck, the problem will come back very soon.
dave, i thought it could have been the throw out bearing as well but i remember last time it went out there was a horrible squeeling noise whenever the clutch was engaged.
Tom i will be sure to check out the rod when i have the tranny dropped next month
thanks to all for the advice!
Old May 5th, 2004, 09:25 PM
If a MC or SC is misadjusted they will build pressure and disengage the clutch.
Make sure there is the correct amount of free play on the MC pedal, I want to say it is 1/2in-3/4in but IIRC it is in metric and I do not do metric.
Ron
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
Something Wrong With The Front End? The Wizard Defender Technical Discussions 13 October 4th, 2006 11:51 PM
Fuel pump relay issues?-- wrong message board..ignore! chuff Misc. Chit-Chat 0 August 28th, 2006 07:29 PM
Whats wrong with this picture? chrisvonc Misc. Chit-Chat 3 April 8th, 2004 09:56 PM
