What's up with the Slop in the Drivetrain? - Defender Source
Old February 7th, 2005, 02:28 PM
spencer08291985
Tim/Spencer
What is up with the slop in the drive terrain?
Hello, my name is Tim Spencer from Michigan, I own a 1997 D-90, 49,000 mile. There seems to be a lot of "slop" in the driveterrain, especially upon slowing down, then speeding up. Is this normal?
Old February 7th, 2005, 03:26 PM
sure. Rovers are known for having slack in thier transmissions. Perhaps you could check your u-joints etc.
Old February 7th, 2005, 03:58 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
In an effort to split out the thread, I think I killed the earlier post. Sorry gang.
Chris von C
[/size]
Old February 7th, 2005, 04:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I have the same issue with mine as well, and have never been able to track it down fully. It seems to be coming from the front, possibly the bellhousing area. New u-joints didn't solve it, considering front axle CV's. It may also be the shock absorbing springs (the coil springs in the disk, not the flower spring on the pressure plate) aren't strong enough and they are bottoming out?
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 7th, 2005, 04:26 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
I read in the latest issue of LRW that some of the "noise" that is accredited to the driveline is caused by the triangle bushings being too old and rotted.
since I dont know anything about rovers..I'm just passing on the info I read in the magazine...
by the way...my 95 has that slop too.
-arbi
Old February 7th, 2005, 04:47 PM
Hans's Avatar
Hans
Hans Haase
Hmmm, now I just have to figure out what Land Rover calls a "triangle" bushing so I can inspect it. But it does make sense, it might be a suspension bonk rather than a driveline bonk.
-Hans
My oil line fix
Old February 7th, 2005, 05:47 PM
arbik
Arbi Karapetian
Hans,
I"ll look it up tonight and post it.
-arbi
Old February 7th, 2005, 11:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I got it bad. It is huge when in locked high with the front end unlocked. If I let off the gas fully in first after getting rolling it chuncks and pops and clanks. It is annoying. To me it feels like slop in the t-case. I remember others complaining about it so I just figured it was normal. All my u-joints are new, and I have new bushings. It might just be the truck.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 8th, 2005, 12:39 AM
arbik
Arbi Karapetian
ok,
just checked the magazine. Its the January Issue of LRW. Its the Rear Radius arm bushings they call "triangle" bush.
Hope this helps.
-arbi
Old February 8th, 2005, 07:36 AM
I agree with Dave, The T-case is the biggest part of the problem. There is slop between the front and rear outputs. I have driven both i front only and rear only and the problem goes away with only 1 drive shaft. And it is not because they are old, when I replaced mine it did the same thing. Auto trannys don't have as much of a problem as they are a bit smother in operation, but if you drive it enough you will get better at not making it do it.
Old February 9th, 2005, 06:35 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I think all Rovers have more slack in the drivetrain than most other vehicles, all the way from the input of the transmission to the drive flanges.
Old February 10th, 2005, 01:37 AM
arbik
Arbi Karapetian
Guys,
Just got back from driving my buddy's "new to him" D90 SW. #451/500 1995 with the manual gearbox.
This truck has 72K miles on her, and there is NO slop in the driveline. NONE WHAT SO EVER.
Mine on the other hand, with 112K on it (same year and model) has TONS of slop.
How does that work out?
Obviously, they "all dont do that" as the dealer told me yesterday morning. So..its something.
I'm probalby going to redo the whole truck one piece at a time...but it'd help to know where this slop comes in most ...
Just an observation...
-arbi
Old February 10th, 2005, 09:49 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Good luck getting rid of your slop. Although, if you are handy with setting up diffs, you can first take those apart and reduce the backlash as much as possible before they start making a bunch of whining noise and be sure to check the inner teeth that mesh with your axles for wear--you will undoubtably need to replace your axles since the splines probably have some wear, also check your hub splines for wear, your u-joints, your transfer case gears, your entire transmission. When you are done with that, check your suspension mounts. Or do in whatever order you want. When you are done with all this, and your back lash is at a reasonable level, I will bet you will have some whining going on that will make all this seem like it was not worth it.
I know you drove one without slop--and good for them!, but it is not factory spec. and I would say they are just the 1%'ers.
Old February 10th, 2005, 12:57 PM
arbik
Arbi Karapetian
...looks like I need to learn to live with slop
Old February 10th, 2005, 01:13 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
It would be interesting to check out the "No Slop" truck. Out of maybe half a dozen transfer cases I've seen (which includes a freshly rebuilt one from Ashcroft and a relatively new one out of a Disco), all of them have had a lot of slop in them. Add to that everything else in the drivetrain everyone has already mentioned, and the overall drivetrain slop is fairly signficant even in a fresh build. It's kinda funny to say, but I wonder if there's something "wrong" with the "No Slop" truck.
Old February 10th, 2005, 05:01 PM
arbik
Arbi Karapetian
Nothing that I could feel. Ran and drove like a champ.
He'll be at the RR5 in April for show and tell
As will my "slop galore" D90
-arbi
Old February 10th, 2005, 08:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Real men have slop.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 10th, 2005, 08:32 PM
no, real men wear kilts
Old February 10th, 2005, 09:45 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Slop is fun. What else can you drive that offers such a challenge??
Locked in low range and crawling on a rocky trail, my 110 sometimes is like a damn bucking bronco!! Who needs a horse??? 8-0
DW
Old February 11th, 2005, 08:38 AM
yeah when I am locked and moving at a snail pace over rocks etc I get worried about something being fubar'ed, makes noises that sometimes are un reassuring.
Drivetrain Failure d901560 Defender Technical Discussions 9 December 26th, 2005 11:31 PM
Griding from drivetrain when i hit the clutch? oldscratchggf Defender Technical Discussions 6 November 29th, 2005 01:59 AM
1990 Range Rover w/37" MTR's and Toy Drivetrain lwg For Sale - Vehicles 0 October 17th, 2005 03:06 PM
109 rolling chassis, drivetrain bulkhead $500 evilfij For Sale - Vehicles 1 June 20th, 2004 07:50 PM
banging in drivetrain prospector Defender Technical Discussions 8 June 14th, 2004 11:17 PM
» Defender Registry
D 90
TommyB
Blue
dmarchand
Add your Defender
