What's this wire? - Defender Source
Old June 2nd, 2015, 04:23 PM
kilr4d
1999 110 TD5
What's this wire?
Noticed a frayed/broken wire hanging down:
Leads back here:
Old June 2nd, 2015, 04:28 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Leads back here:
magnetic or inductive proximity switch, must have some sort of speed sensor fitted, not OEM so just pull it off
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 2nd, 2015, 04:30 PM
kilr4d
1999 110 TD5
Ok. I just wanted to make sure it wasn't part of the ABS or traction control.
Thanks.
Old June 2nd, 2015, 05:05 PM
roverman2010
1985 LR 90 200Tdi
Thanks.
Your funny, may I suggest getting a workshop manual and parts books, before spending to much time asking Q's and spending money.
There are a lot of web based sites for these.
Your landy is just a bit rough around the edges, it will polish out.
Good luck and enjoy
Td5 right, first to check is the injector loom (harness) these leak oil into the ecu. Again check the UK web sites for this.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old June 2nd, 2015, 05:18 PM
A thread title that an EOD guy would never use.
Old June 2nd, 2015, 05:22 PM
probably from an aftermarket cruise control setup.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 2nd, 2015, 05:52 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
that he'd use once
Old June 2nd, 2015, 05:53 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hall or read indicator.
I would like to install this item through the backing plate of the handbrake looking to the inside of the brake drum.
Old June 2nd, 2015, 05:57 PM
DefenderMd's Avatar
DefenderMd
Ben
looks like hall sensor. which, good call, could be an abs thing. other than, old rover.
ask all the questions you want.
Old June 2nd, 2015, 06:23 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Could have also been for an old style GPS that used to have a speed sensor...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 2nd, 2015, 07:05 PM
DefenderMd's Avatar
DefenderMd
Ben
Never heard of that.. but if its a thing... very rover
Old June 2nd, 2015, 09:43 PM
kilr4d
1999 110 TD5
Thumbs up
Thanks everyone.
That actually wasn't a joke. I was under the impression that TD5's have a rudimentary electronic traction control system. I was wondering if it was a 3 channel setup like the early Fords have.
Thanks. Will do.
Old June 4th, 2015, 03:51 PM
kilr4d
1999 110 TD5
Thumbs down
Unfortunately you are correct...
Old June 4th, 2015, 03:57 PM
roverman2010
1985 LR 90 200Tdi
You should be able to open up the ecu and clean it out, wisely choose which cleaner, something plastic and pcb friendly.
Check on the harness price from the UK, I do not know if the harness can be cleaned out enough.
Also more Td5 advise will come the UK as Not very many Td5 savvy here
Good luck
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old June 4th, 2015, 05:16 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I replaced the injector harness on mine for that exact reason. Oil migrates down the harness between the wire & insulation, all the way to the ECU. Strange, but true.
You may experience difficulty starting, reduced mileage and loss of power among other issues.
It's pretty easy to swap out. After a couple weeks, clean out the ECU plug again as the last of the oil in the main harness migrates out.
New harness should cost you about $100
Don't by the Britpart or Bearmach. Go Genuine for something like this.
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
AC wire loose in passenger footwell artm Defender Technical Discussions 3 November 25th, 2003 11:43 AM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
