Whats this switch? - Defender Source
Old June 30th, 2012, 08:54 PM
texrover's Avatar
texrover
Jason
Whats this switch?
It's to the right of the column in my new to me 200tdi 110
It's my first diesel and first non-NAS so I'm sure I'll have tons of questions
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old June 30th, 2012, 09:26 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
You're going to have to identify what wires are connected to it; it is not stock.
Old June 30th, 2012, 09:43 PM
texrover's Avatar
texrover
Jason
Yeah that's what I thought
I've been running wires all day and now I need a new tester
Nothing happens when I toggle it but then again neither do all the stock switches or the turn indicator
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old June 30th, 2012, 09:47 PM
defeyago's Avatar
defeyago
Santiago
ī96 Defender 110 VGTdi SW County
The "stick" one I donīt know and as Andrew said itīs not stock. The other one with the ambar light is rear fog lamp wich NAS models donīt have.
SANTIAGO
ī97 Defender 110 Tdi SW
ī04 Freelander Td4 5 dr.
ī97 Alfa Romeo 146 TD (Sold)
ī95 Volvo 850 GLT Estate
ī94 Discovery Tdi (Webasto equipped)
Old June 30th, 2012, 10:19 PM
ajh
Andrew J. Hutton
My guess is there is aux lamp wiring somewhere for lamps they removed; but you never know until you look.
Old June 30th, 2012, 10:39 PM
Definitely non standard. If you don't need it and it does nothing, remove it!
Old June 30th, 2012, 10:46 PM
texrover's Avatar
texrover
Jason
Yeah but after three says in the drive I have no drips on the pavement - it might be the "act like a rover switch"
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 1st, 2012, 08:45 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
That's one long switch, are you sure it is a switch and not a hand throttle?
Old July 1st, 2012, 01:13 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Have you checked the fluids?
Old July 1st, 2012, 04:30 PM
texrover's Avatar
texrover
Jason
Yeah good point!
I started on electrical since I realized some obvious issues as I was backing it in the drive and just started there as it was apparent I was going to need to order some parts and wanted to get that rolling before anything else. Have only inspected steering fluid and air cleaner - started in the front and moving back. need to check the rest next. Thanks for reminding me of the obvious!
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
