Whats this part called? - Defender Source
Old January 6th, 2012, 10:40 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
Is this one piece or more then one? Mine is totally rusted and I worry my kids are going to need their tetanus shot boosters to keep climbing over it - any one have the part number or a link to the part?
can I remove/replace this without taking the truck apart?
my kids thank you
Jay
Old January 6th, 2012, 11:05 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
That is called a T-post and includes the vertical door post as well. It's one piece. You will need to remove both doors and drill out the pop rivets that connect it to the rear bed. You will also need to remove the floors. You will need to repaint it to match the truck as well as the new pop rivets in the rear bed if you want. Not a bad job just expensive. sorry
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
grnrvrs's Avatar
grnrvrs
Paul
88
B-pillar, also includes the vertical portion between the 1st and 2nd row doors. Small PITA.
1970 SIIA 88, Sold
Old January 6th, 2012, 11:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do you have door seals mounted to them? If so is that where it is rusting?
Old January 6th, 2012, 11:26 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
there is nothing left of the door seal on the rear doors - and I stare at that rusted sill everyday - and watch my kids climb on it - really the only noticeable rust on the body - I think - Ill take a picture for you tomorrow but need to get up to la so you can see my 110 soon
Old January 6th, 2012, 11:33 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
finally found it this right
Old January 6th, 2012, 11:46 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
anyone know where to find one?
or two for that matter none of the uk sites have pictures of anything to verify Im looking at the right thing
this
http://www.brit-car.co.uk/product.php?xProd=138902
or this
http://www.johncraddockltd.co.uk/pro..._from_1986.php
I have a 84 so not sure if its different
and not sure its worth the cost right now! that could buy alot of tetanus shots
Old January 6th, 2012, 11:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
On my 110, I removed the seals on the sills, drilled out the spot rivets, removed the rusted sills, Fixed the metal underneath and finally put the seals on the bottoms of the doors. ECR does it to all the NAS 110s. It is a pain but a very doable job at home.
Old January 6th, 2012, 11:55 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
http://WWW.yrm-metal-solutions.co.uk...l-ns-235-p.asp
These guys have nice galvanized sills and all the other little galvy pieces that you might need. The shipping is not bad at all
Old January 7th, 2012, 12:28 AM
bjf's Avatar
bjf
barry f
94 ST #395
If I did it again, I would drill out spot rivets, grind off rust, prime and put these on:
http://www.entreq.de/products/interi...ce-strips.html
Old January 7th, 2012, 12:33 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
barry you have not see the "rust" think more like a granola bar not something with surface rust - I dont think I could stop grinding once I started
i think i might get those from yrm along with a few other pieces - then beg people to come over and do some heavy lifting with doors etc
J
Old January 7th, 2012, 12:50 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
i would say the entire length bulkhead to behind the rear door - I have realistic expectations for my truck and i dont want to get into a complete tear down - more for what I would find but I want it to not stab my kids as they get in and out so I think I want to at least replace things that would make the truck better in the short term if its something that doesnt cost a arm and a leg and I could tackle mostly myself
Old January 7th, 2012, 12:56 AM
bjf's Avatar
bjf
barry f
94 ST #395
pics would help
Old January 7th, 2012, 01:06 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
here you go - front right and rear right
they are worse in person my phone doesnt capture their true rusted nature
Name:	Photo Jan 06, 10 04 48 PM.jpg
ID:	45733   Click image for larger version
Name:	Photo Jan 06, 10 05 10 PM.jpg
Old January 7th, 2012, 01:21 AM
bjf's Avatar
bjf
barry f
94 ST #395
looks like surface rust to me
Old January 7th, 2012, 06:35 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
Not to bad! just use some sand paper and see if you can see some shining metal underneath this rust.
Old January 7th, 2012, 10:46 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Jay,
if it were completely swiss cheese, I'd say go through the hassel of replacing the part, but since it is surface rust and not structural, my advice would be to:
1) wire brush throughly as possible;
2) treat with rust nuetralizer;
3) paint two coats of POR-15;
4) get some rattle cans of Stratos Blue made up and finish it off.
that would be a weekend project as opposed to tearing apart the truck. While your at it, order additional POR-15 and treat all the areas you want to save until you end up doing a major tear down.
Replacing that T-post as a short-term solution would drive you nuts and take way too long. Also, if you look for two rear steps on the board or RN, the kids probably won't even come into contact wit the sills when their climbing in and out. That would be my solution. The worst thing you can do is throw money at partial fixes. They add up and by the time you're done with all these little fixes, you probably could have torn the truck down to the frame and replaced everything at once for less.
Anyway, that's what I'd do. Others may agree or disagree, but knowing your purpose and intent, I think that's the best way to go.
Also, I'll send you those interior pieces first thing next week.
Old January 7th, 2012, 08:00 PM
61rover's Avatar
61rover
John Crouse
Jay I replaced both B-pillars on my 110 last year. It really wasn't that hard. I did galvanize mine before installing and that actually made the job 1000% harder. Shoot me a note if you want to discuss. Check with Eric at Atlantic British (He's on the forum). That's where I got mine.
part
What is this part called? kennybahr Defender Technical Discussions 5 February 2nd, 2008 07:16 PM
What is "that" part called? / update, too Emerson00 Defender Technical Discussions 2 April 2nd, 2007 12:39 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
