Whats this leak - Page 2 - Defender Source
Join the Defender Source Community Today
Old July 27th, 2012, 08:14 PM
Originally Posted by texrover View Post
Seals but also two half moon oil plugs (x2) you might check that they are seated properly at the rocker cover
That's just for the 200tdi, right? I don't think I had that on my 300.
SDO Instagram
SDO Facebook
Old July 27th, 2012, 08:29 PM
texrover's Avatar
It's for valve gapping (the link) for 200/300 not sure about the plug present on the 300 or not. I came across it searching for the part number on the plug
But the article does state checking gaps every 12k miles and thought it would be handy
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old August 1st, 2012, 02:02 PM
bossman429's Avatar
Sooo I pulled the valve cover and the gasket seemed brand new, cleaned everything off, and re-set it on the head. Then I realized the breather valve/seperator didn't have a gasket, so I think that was the issue. Put some High Temp RTV on it and alls well.
Of course I snapped a valve cover bolt and couldnt back it out. Turning a 5 min project into a 2 hr ordeal. After driving all over looking for a metric tap set I was able to re-tap it for a M6x1.00 bolt and get the valve cover back on.
Took it for a little drive to today and its dry as a bone. I certainly think it was the breather valve that was weeping. No way could that rubber gasket that was in brand new condition have been leaking.
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 08:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 02:21 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 08:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
