What's this called? Where do I buy one - Defender Source
Old June 15th, 2015, 05:23 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi all. I have a 94 D90 ST NAS.
My mechanic buddy is replacing fuel injectors, ECU, etc.
I sometimes struggle understanding his broken English.
Anyways, he sent me this photo. He's pointing to a tube that is cracked and needs replacing. What's it called? Where do I find one?
Thanks for being patient with these rookie questions!
ID:	122960Click image for larger version
Old June 15th, 2015, 05:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Fuel rail
Old June 15th, 2015, 05:35 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Originally Posted by Brewie212 View Post
Fuel rail
Excellent. Thanks. Ok I spent 10 minutes googling where to find one. Anyone have a suggestion?
Old June 15th, 2015, 06:03 PM
If you use a fuse rail from a later truck it will have a sSchrader valve for checking fuel pressure. My 95 has one, I am not sure when rover started putting the scSchrader valve on the fuel rail. Ibelieve a fuel rail from any 14 cux or GEMS truck will work. FWIW the fuel rail with the sSchrader valve has a different location for the fuel line connection. I was going to install a later fuel rail with the schradermySchrader valve on my 1991 RRC but the fuel lwouldn't reach. Some people have installed the later rail on classics with no issu.IDK about the defenders it may work. Please excuse typos I am posting from my phone
Old June 15th, 2015, 07:18 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Would this fit? Click image for larger version
Old June 15th, 2015, 08:03 PM
Originally Posted by EnduroPro View Post
Would this fit?
Who else freaked out when seeing your battery charge on their iPhone?
Old June 15th, 2015, 08:13 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hahaha charging now. I usually address it at about 7%.
Old June 15th, 2015, 08:16 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I noticed that and thought fuel rail isn't the only problem! Glad you have it sorted.
Old June 15th, 2015, 08:40 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I confirmed that it'll fit. Purchased. Arrives Friday.
What is this part called? kennybahr Defender Technical Discussions 5 February 2nd, 2008 07:16 PM
What is the thingy called?? Buckon37s Defender Technical Discussions 6 August 20th, 2007 11:58 PM
What is "that" part called? / update, too Emerson00 Defender Technical Discussions 2 April 2nd, 2007 12:39 PM
what's this goop called? Gkase Defender Technical Discussions 7 October 31st, 2006 10:17 AM
What is this called? cgalpin Defender Technical Discussions 7 December 19th, 2004 12:30 AM
