Whats the deal with the windshield wipers? - Defender Source
Old September 2nd, 2015, 12:53 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I live in Florida. We get a lot of rain here. When I turn them off they stop about 5 inches short. If they run for a long time they go past the wind shield and when I turn them off they go all the way down . It's like they have a mind of their own. Is this just one of those cases of "that how rovers are" or is there an upgrade or fix for the wipers?
Eric
Old September 2nd, 2015, 01:08 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Few possibilities...worn spindles, or worn drum adapters. Remove and inspect
Old September 2nd, 2015, 01:10 PM
Most likely your wiper wheel boxes are loose. These can be tightened up. Could also be wear in the wheel box and you could replace or flip the gear. Have a search. There should be some detailed information around here somewhere.
Old September 2nd, 2015, 01:43 PM
CavemanDiesel
Eric Smirh
1985 D90
Thanks for the info
Old September 2nd, 2015, 02:13 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
I just replaced my wheel boxes. You might be able to rebuild them, but they're cheap enough to swap out.
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
Old September 2nd, 2015, 03:53 PM
fpdigit
Peter
1985 LR90 2.5NA
I had the exact same problem and spent a few days fiddling with mine. Perhaps your gearing is worn, but more likely the rod sleeve is just sliding back and forth where it connects to the wheel box/motor mechanism. The design of the wipers places a lot of force on the crimped mounting points and even a tiny amount of play translates to a significant variance in the wipers' travel. If this is the case you can try re-crimp/shim the sleeve the best you can.
You'll probably also find that the amount of travel varies by an inch or so depending on whether you have it set on hi or low. Go figure!
D90 windshield wipers D90grl Defender Technical Discussions 7 February 20th, 2014 02:15 PM
adjusting windshield wipers kellykortman Defender Technical Discussions 7 October 2nd, 2013 11:49 PM
Any 3rd party windshield wipers? cdnpaul Defender Technical Discussions 36 April 27th, 2008 09:36 PM
Windshield Wipers kennybahr Defender Technical Discussions 2 January 5th, 2008 10:55 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
