What's the actual Mileage? - Defender Source
Old April 7th, 2005, 10:26 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
If you're running 285's and a 4.11 gear ration; anyone have a conversion formula for determining actual mileage I'm putting on the vehicle?
Old April 7th, 2005, 11:48 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I run 285's and would be interested in knowing this as well.
This is what I have heard..
Larger tires will increase you top speed(increasing milage) but it will decrease your bottom end power.
Old April 7th, 2005, 12:26 PM
I made a calculator in excel, tell me what ya think?
Edit: Type over the white sections too put in what ever size tire you have.
Edit 2: changed some backwards calculations
Edit 3: ok another fix in calcs
OK I was thinking f adding a few things, like what your RPMs will be at, a T-case area that you can change the high range and low range ratios, anyone think of anything else?
Old April 7th, 2005, 01:08 PM
axle ratios?
Old April 7th, 2005, 01:16 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
When I went to 285s my speedo started reading correctly according to my GPS. I figure my truck actually has less miles on it than the odometer says as it ran 265s for its first 100,000 miles.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old April 7th, 2005, 01:25 PM
Originally Posted by JimC
axle ratios?
On there already.
What GPS, I have found that most GPS's don't read very acuretly, I always use the Radar traps on the side of the road to check the speed.
Old April 7th, 2005, 02:48 PM
Ntajeep
Matthew Bremner
1997 AA Yellow D90
I had a very similar situation. Since switching from the stock A/T's on my '97 to 285/75/16 SSR's = 33.9' according to Interco's website, I have had a more accurate read from my speedo compared to both a GPS and a speed trap device.
-Matt
Old April 7th, 2005, 06:06 PM
scoloco's Avatar
scoloco
'94 D90 ST
Same here. Upping to 285s from 265s seems to have fixed the speedo. With the 265s I had people complaining over the CB that I was driving too slow (speedo was reading ~5mph slow at 70). Now that I've changed my gears, I expect it will be back to reading fast. Changing 3.55->4.11 is about 2% change (I think) and I think that is just less than the tire size change.
Old April 7th, 2005, 06:25 PM
OK I added T-case gearing, trans gearing and a RPM section.
Tell me what ya think, is it too hard to understand?
Old April 8th, 2005, 09:06 AM
scoloco's Avatar
scoloco
'94 D90 ST
OMG - thats one helluva colour scheme! Once I figured out how to use it, interesting. I guess the gear change is more drastic than I thought it would be.
Note you cant have both metric and non-metric tire size filled out at the same time.
Old April 8th, 2005, 02:40 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I'm using a handheld Magellan. It's very accurate in my tests. I've tested it against speed traps too. It got me out of a ticket a couple years ago. Cop claimed I was doing 85 in a 60. I dl'ed my logs and brought them court. The were admitted by the DA and showed that I was only doing 66. They let me off with court costs.
Old April 11th, 2005, 04:25 PM
Yes you cannot have oth metric and non-metric tires for both old or both new at the same time, but you should be able to have an old metric and a new non metric or vise versa. I also know I need to work on the colors, I'm not an interior decorator
Hmm, ok, I have used a few and they always seemed to be off.
Old April 12th, 2005, 08:24 AM
scoloco's Avatar
scoloco
'94 D90 ST
So how do you know they are off? I never trust my speedo. I dont think the speedos in my cars have been accurate at all (well, cars since I sold my chevy).
Old April 12th, 2005, 08:29 AM
I have compaired them to people with new cars, and to rader signs on the side of the road, and GPS to GPS.
ac
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
Gas Mileage mdmccallum Defender Technical Discussions 2 October 6th, 2004 12:14 AM
Actual Tire size? revor Defender Technical Discussions 8 July 8th, 2004 10:10 AM
Mileage Question boshea Misc. Chit-Chat 4 April 6th, 2004 03:22 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
