What's that thick black wire from the alternator? - Defender Source
Old January 21st, 2014, 01:12 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
I have a 200 TDi in a 110. There's a thick (around 8 gauge?) black wire going from the back of my alternator to the frame, right near the front left wheel suspension. The wire is about 10 inches long & is coated.
It eventually wore against an engine mount so bad that it apparently started to arc, causing a bunch of white smoke & the wire has now burned in half.
Is this a ground wire? I thought engine ground straps were bare, like a flat braided copper. And why did it arc? If it was neutral, it shouldn't arc....?
I can't find it on the parts manual
Regards
Old January 21st, 2014, 01:22 PM
Sounds like a ground wire. On mine is runs from the block to the chassis, not the alternator. There is also one from the starter motor to the block.
Old January 21st, 2014, 01:28 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Regards
There should only be one black coated earth wire on the front of the starter motor to the engine block, and a flat braided wire from the block to the chassis in that area.
disconnect the battery and remove that wire, from the alternator you should only have two #6 and a #14, don't quote on the sizes.
I can only think a PO fitted a extra earth wire to the alt but is not really needed if all the bolts are righty tighty, why the arcing FK's. maybe a picture or two would be helpful
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 21st, 2014, 01:57 PM
Axel's Avatar
Axel
jack
Is yours from the block to the chassis coated, or bare?
------ Follow up post added January 21st, 2014 12:58 PM ------
So no coated wire from the alternator to chassis?
------ Follow up post added January 21st, 2014 12:59 PM ------
Good idea but I can't get a picture - it's in a shop about 30 minutes away. If they still can't figure it out by tomorrow, I will snap a pic.
Old January 21st, 2014, 02:07 PM
I can't recall if mine are both insulated or not. Could look later. I suspect these things change over the years. Can you take a photo? I think the block connector might be one of the alternator mounting bolts.
Old January 21st, 2014, 04:40 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
This may help you
Regards
Axel:
This why test lights were invented.
Since you don't state precisely where it attaches in the back of the alternator and if it is actually bolted to the frame it is hard to tell if it is (+) or (-).
You say it rubbed through the insulation and arched????
A (+) wire hooked to the "back of the alternator" would surely arch if it had insulation worn through and attached to the back of the (+) alternator lead and disappeared somewhere near the frame under the vehicle (to presumably connect something up that draws (+) current).
OR
It could be strictly a PO stupid wiring that is very very commonly executed by people who have no real fundamental understanding of vehicle wiring.
Here are the cliff notes of grounding (-) current as follows.
The vehicle, engine, frame, transmission, and suspension (mostly) is grounded (or should be).
The (-) battery terminal is connected to the frame, the frame has a ground cable to the engine, and this creates (-) ground. Knowing this, there is NO NEED to connect separate ground wires from or to the starter or alternator.
BECAUSE
Anything bolted to the engine will be grounded with (-) current. If the engine is grounded and you bolt something to it that is made of metal that conducts electricity (like steel or aluminum) then it will also be grounded. So running a ground wire to something that is already grounded is a waste of resources. In summary running a ground wire to something that is already grounded is unnecessary for obvious reasons.
EXCEPT
Except for the case where you have a bad ground already and someone who doesn't know how to fix the problem runs a new wire to say ground an alternator that is not charging because of the faulty ground between the engine and frame or between the battery and frame. In this case the real cure is to fix those faulty grounds and NOT run an new ground wire.
I have fixed so many electrical problems by simply removing the ground cables, cleaning away old paint and corrosion and reattaching them. A bad ground can cause all sorts of weird problems as electrical devices that should be grounded search for a ground. This causes things like accelerator cables to glow red and catch fire as an example.
Hope this helps.
RDavisinVA
Old January 22nd, 2014, 12:42 AM
Axel's Avatar
Axel
jack
Good points, Richard
I called the shop this afternoon to tell them some of the things you guys suggested & they said "Don't worry, we got it." So naturally I'm worried (because a prior shop had exactly said that before attaching that alternator wire!) I'll let you know.
Jack
Old January 22nd, 2014, 07:53 AM
rovertrader's Avatar
rovertrader
Dale
A shop manual will also have proper wiring schematics for the entire truck- think if you were half way home from a movie after dark, or any time any where. A rudimentary tool kit with test light and said manual are basic kit for every Rover...
Old January 22nd, 2014, 08:06 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Good points, Robert
Jack:
Because I started working on Land Rovers at the dealership during college summers and have been at it ever since, it is hard for me to understand why anyone would own an 80s 90s and older Land Rover who does not turn their own wrenches.
As Dale suggests, there are those publications that explain repairs and provide other data like wiring diagrams. Proper tools are available anywhere and good deals show up on Craigslist for used tools sometimes complete with large rolling cabinets.
Being self reliant is much better than being at the mercy of repair shops that often don't understand what they are working on, much less how to fix it. Yes there are good shops with specialists like Trevor, Matt, Pendy, and so on - but there are bad ones as well that have no clue.
Hope this helps and good luck.
RDavisinVA
Old January 22nd, 2014, 08:43 AM
87 D110 (Ruby)
Well said on all counts Robert!! Btw Vegemite arrived for ya!
Old January 22nd, 2014, 08:57 AM
Axel's Avatar
Axel
jack
Hello Richard
Short answer: because of my loyalty to friends, mixed with some naivety.
I've been a car magazine & calendar photographer & writer for well over a decade, including traveling as a photographer for race teams & contributing to automotive books. During that course of time I built up friendships with great mechanics & car vendors. A few years back I thought I'd build the ultimate car photography vehicle. I polled these friends. They told me to get a Land Rover Defender. EVERY ONE OF THEM said if I bought one, they wanted to work on it. So I did & they have.
I also have the stupid or naive philosophy that, if a mechanic is helping me with something big, like fabricating AC pulleys & while in there he determines I need a new alternator, I say "Sure, go ahead & replace that too" rather than "No, I can do that, don't touch it."
Yes, I turn my own wrench & I have proper tools (in a rolling cabinet - with a Binford sticker on it!). But this wire is probably related to installing the 200 TDi in place of my 2.5 NA, & then adding a higher capacity alternator. Such an install could not be accomplished in my garage & I could find nothing in any manual or guide about that combination, hence my post.
Old January 22nd, 2014, 09:29 AM
Now that you have been properly censured by the Board of Directors, is it possible that you could include a pic of this mysterious wire?
To my limited knowledge, there should be only a brown or brown with orange (or maybe it's red) tracer coming from the alternator. The other wires are the excitation wire (wired onto the big brown wire), the idiot light wire and the tach wire.
As per this fine web-poached image below:
Old January 22nd, 2014, 09:53 AM
Axel's Avatar
Axel
jack
Thanks Bill
That does help
I hope to have a photo of mine to post by this afternoon.
Regards
Jack
Old January 22nd, 2014, 09:58 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Hello Robert Short answer: because of my loyalty to friends, mixed with some naivety...
OK excellent.
As Bill helpfully suggests, showing a picture of the wire will go a long way to understand what is what with the black wire.
Question for Bill: What tool are you using to write over the photos? Snag-it?
Can't wait to add that to the next party snack table, thanks.
RDavisinVA
Old January 22nd, 2014, 11:01 PM
Axel's Avatar
Axel
jack
black wire from alternator
The black one which burned up was replaced by this thick copper ground cable, in clear sleeving, shown at the bottom of this photo of the back of my alternator. Out of the frame of the photo, it attaches to the frame.
At least the replacement fixed the problem & it runs fine. But it's still odd that, as a ground cable, it would arc & need sleeving.
Old January 22nd, 2014, 11:07 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Unless I'm looking @it wrong is that some sort of ground from the mounting bracket bolt! Funky....
Old January 22nd, 2014, 11:09 PM
I agree with Bill. It is completely unnecessary in my book.
I don't have any wires going from my alternator to the frame.
B+ goes to the battery
D+ goes to the dashboard alternator light
Thats it.
Old January 23rd, 2014, 08:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That is a PO ground...
Jack;
The pictured location is simply where some PO decided to connect your ground cable.
If it's the only ground cable then it is necessary,
BUT
The ground should actually go between the frame and the transfer case or gearbox and if this is not present or not making continuity, then this new ground cable is needed.
OR
If you have the continuity between the frame and the transfer case or gearbox with a different (-) ground, this cable in the picture is completely redundant.
The good news is, either way, this cable hurts nothing and can only help with (-) grounding although there are much better locations for a (-) ground.
Hope this helps.
Robert not Richard because I'm not a dick (at least not always)
RDavisinVA
Old January 24th, 2014, 10:01 AM
Axel's Avatar
Axel
jack
Thanks everyone.
At least I now don't feel as much of a dufus since I'd guessed right that there's not supposed to be a ground wire there - it just didn't make sense. But why this one has to be shielded is still strange. Maybe it was arcing to another wire on the back of the alternator.
I was wondering if this wire was something unique to transplanting a 200Tdi.
Thanks to your comments I'll check to see if I have the preferred ground between frame & transfer. At least it's running great now, thanks to the mystery wire & defendersource
Regards
Jack
ac, alternator
Is it ok to run 4 guage wire from Alternator to battery? Neil McCauley Defender Technical Discussions 24 January 11th, 2011 02:34 PM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
