What's normal water temp range? - Defender Source
Old May 27th, 2006, 12:58 PM
btate
Bryan Tate
d90
Finally got the VDO's working, I had a time getting the correct sender. I think it is still too long....
Anyway, what's the normal running temps and ranges with hot/humid conditions?
(94 d90, no A/C)
It was running hot in stopped traffic before I put in fan clutch, therm.
I am trying to have a number in mind that I can begin to worry if it gets too hot
(Now that I can actually see what the temps are)
Bryan
Old May 27th, 2006, 01:10 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I usually start paying attention when it gets close to 210 degrees
Old May 27th, 2006, 04:24 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I too get concerned at about 210, and I shut it down if it goes any higher. I like to see mine stay at or below 200 personally.
To help that, I run a 160 degree thermostat now, and I like it. The truck rarely sees more than about 195. Normal for my truck is now around 180-185, and then in traffic or on the trail it'll creep up to about 190-200. I suspect this is because of the stock viscous' settings. I know the engine is designed for a normal of 190, but after all the cooling issues I've had I feel a little better seeing that guage below 200.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old May 27th, 2006, 05:40 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I agree with Dave completely. Mine operates in the same range and if it goes above 200, I get itchy.
Old May 27th, 2006, 10:18 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Mine, with the TVR-modded engine, runs hotter. Been two years now with no damage, running up to nearly 228 (rarely) while rock-crawling uphill in desert heat. AC fans come on at about 220 degrees and usually knock the temp down in a couple of minutes. I went to 235 one time when fuse to my old electric fans blew. Shut her down and did repair on the spot -- no engine damage. 210 is no great shakes, but 220 makes me nervous, and above 220 and I'm looking for instant solutions. I think I've got it licked now, but this summer will be the final test....
Doug W.
Old May 27th, 2006, 11:41 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine runs at a rock-solid 195 in the summer, sometimes lower but never higher.
Doug.... you can get lower temp switches for the A/C fans if you want. It's in the FAQ what you have to cross reference. I have a 165 degree switch running my electric fans.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 28th, 2006, 12:29 AM
Doug's Avatar
Doug
Doug Walker
Hans, there's another thread running on this topic, and I'm confused:
Dave Souza posted: "I'm getting confused here myself with the different sensors. The A/C cutoff switch is right on the same housing as the thermostat, has two male spade poles and usually has a small brown plastic connector (two wires of course). My understanding is this kills the AC at like 220 or something. This is what we usually remove to put in the VW temp switch."
Does that sensor control only the fans, or is it also used when the AC is turned on, to cut the compressor if the engine coolant temp gets too high? Anyone know for sure?
Doug W.
Old May 28th, 2006, 04:57 PM
Etrier
Jonah Thompson
1994 D90 ST
I'm still debating between replacing the viscous and switching to electrics. Being an old jeep guy I have another question - anyone running electric water pumps? Any downsides to the stock one that might be improved with a big electric high flow one?
Still wondering about the A/C cut-off or turn on provided by the switch in question
Old May 29th, 2006, 12:17 AM
Hans's Avatar
Hans
Hans Haase
I honestly don't have A/C on mine, so the sensor was there but not connected to anything. When I get a chance, I'll go over the wiring diagrams and see if I can determine the exact use for it.
Or, you can also test what it does by removing the leads from the sensor, and jumpering it to see what happens when the engine is at a more normal temperature.
-Hans
My oil line fix
water
oil pres + water temp gauge??? revtor Defender Technical Discussions 1 July 10th, 2007 09:35 PM
95 D90 temp sender range naeirie Defender Technical Discussions 2 April 27th, 2005 12:16 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 08:47 PM
