Whats my EFI worth? - Defender Source
Old March 28th, 2013, 09:20 PM
wantone
Rick Thompson
94 ST #1222
Whats my EFI worth?
I have had it. I am going to get the RPI carb kit & sell the EFI off my 94 GEMS. Dont care about devaluing mt truck as I will never sell it. So whats it worth?
Old March 28th, 2013, 10:44 PM
Complete engine harness computer distributor all sensors fuel pump nothing cut in working order or just the EFI bits that are easy to remove, no harness etc.?
Old March 29th, 2013, 08:27 AM
wantone
Rick Thompson
94 ST #1222
Everything i dont need after i carb it & put a mallory dizzy in
Old March 29th, 2013, 09:03 AM
Diz is not associated with EFI. You can keep it and save a few bux. (EFI gets its timing input from coil tho)
Get scrap value for the aluminum intakes. The rest of it? meh. EFI ECU worth maybe $50, the remaining odds and ends, not much.
There are some things that are of use. If the rubber hose from the MAS to the intake plenum is good, then someone can get some use out of it. I personally would just give it away to someone who needs it. Same with the upper plenum with its stepper motor.
Old March 29th, 2013, 09:18 AM
why have you had it? Is it because you can't get it setup correctly?
there are tools and help out there ...
Old March 29th, 2013, 09:21 AM
Also, don't forget that you have a high pressure fuel pump in the tank that will blow out the needle valve on the carb. You'll have to kill the tank pump and use a low pressure one. Also, the pedal linkage is gonna be weird.
Old March 29th, 2013, 09:27 AM
Assuming you pull the EFI harness and all the senors and the intake, I would say at least $500 and probably more like $1000. Maybe you could even get $1500 from a burn victim.
Old March 29th, 2013, 09:35 AM
You're mental. However, out on the left coast they seem to think that Classics are worth 15 grand for one that goes for 1500 around here. Those suckers would pop on 1000 clams for sure.
Old March 29th, 2013, 09:37 AM
I would pay $500 right now and I am cheap.
Old March 29th, 2013, 09:44 AM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
A 94' came with 14cux Hotwire injection not gems. Are there known problems with this harness/ecu? I may have someone interested.
Is it worth my money? JBurt Misc. Chit-Chat 9 February 28th, 2006 12:57 PM
EFI fuel pump options headdamage Defender Technical Discussions 0 August 11th, 2005 03:21 AM
Factory subwoofer worth? UpnOver Misc. Chit-Chat 1 May 7th, 2005 11:59 AM
Is This 97 D-90 Worth Purchasing? jchan88 Defender Technical Discussions 17 December 17th, 2004 05:25 PM
What do you guys think these parts are worth? Chris Cox Misc. Chit-Chat 2 January 26th, 2004 06:06 PM
