What'd I do wrong? - Page 2 - Defender Source
Old December 14th, 2014, 09:07 PM
scrubs
henery
1974
Thanks, Parents know I need health insurance and not full-time yet at new job let me use their car....bit old for it
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Originally Posted by scrubs View Post
Last night after being stopped for one headlight I decided it's time to clean the terminals on the 1987 ex mod 110.
After successful clean and light inspection put fuel panel back into place. .....no headlights, no electricity to them nothing.
Any ideas?
I had a similar experience. First night I drove, happened to be raining? Most of my fuses failed. Think it was just their time and lucas's curse. replaced them with genuine german fuses (which almost fit) and have not had a problem since.
BTW.. all the fuses looked fine, but few worked reliably. They were the junk with the paper in them.
I figured I'd be chasing down shorts all winter.. but ... knock on wood It was just a matter of fuses and vibrating the sockets and connections a bit.
Old December 14th, 2014, 09:11 PM
scrubs
henery
1974
Where I'm frustrated at is, all the lights worked until I pulled my head up from bolting the fuse panel back in place
Old December 14th, 2014, 09:36 PM
scrubs
henery
1974
Don't suppose anyone knows the part # for 1987 ex mod 110 turnsignal stalk?
Old December 14th, 2014, 10:10 PM
PresidentGod
Jacob
'87 110CSW-sold; '88 110CSW-sold
Originally Posted by Capt Milks View Post
The key switch might have a loose wire or could be bad.
Nice. This is not uncommon, the ignition switches are not that great. Good idea!
Old December 14th, 2014, 11:00 PM
scrubs
henery
1974
Just got back from trying that too, seems to have electricity passing through.
For fun did pull the harness apart enough to put a hot wire between to the plugs & everyone of the connection(all lights) worked that way.
Just no juice upto switch/stalk.
Old December 15th, 2014, 12:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Scrubs - do the high beams work? I had a connection for the lights on mine go at the hi-low beam/ blinker stalk and not the light switch itself. Pretty similar situation - I was changing the front marker light to LED with WeatherPack connectors and once done my main headlights wouldn't go on but the highbeams would. I just took the wire for the highbeam and put it to the low beam line. So low beams do work but Hi beams don't. It's been a few months so I might not be exact in how I fixed it. I do know it was the hi-low beam/blinker stalk.
And I do remember it being a tricky wiring setup. I kept thinking my light switch is fine why the hell aren't the lights on. IIRC power goes to the light switch and then the hi/low beam connection. Or maybe it's backwards - like I said it didn't make sense. The "dip beam" like Jeff said makes it confusing while reading the wiring schematic too.
Hope this helps.
Old December 15th, 2014, 12:08 AM
scrubs
henery
1974
Well, just walked back in from switching ignitions n it's not that either.
Don, I believe your correct being the stalk it's self.
Whenever I hook a hot wire to any of the lighting connections I get light really good light,better than before.
Figuring the stalk has been working but not to 100% & after cleaning the fuse panel termnals finally pushed it too far with good juice going through it.
is this possible?
Old December 15th, 2014, 04:52 PM
scrubs
henery
1974
Update,
This morning took 6 way convoy switch apart and a long brass screw in the center fell out, upon reattaching it the lights came on.
Go figure, I'd never guessed to look there.
All is good for now.
Thank you all!!!
Old December 15th, 2014, 07:57 PM
DefenderMd's Avatar
DefenderMd
Ben
Oh yea.. my lights worked ALL funky till the switch got some exercise.
Old December 15th, 2014, 10:18 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Scrubs - glad to hear you figured it out. I should have remembered you have an ex-MOD truck and mentioned that - I think someone recently had the same/similar issue.
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
This is just wrong shawnpalmer Misc. Chit-Chat 8 September 13th, 2006 02:57 PM
Fuel pump relay issues?-- wrong message board..ignore! chuff Misc. Chit-Chat 0 August 28th, 2006 07:29 PM
whats wrong? jperakis Defender Technical Discussions 9 May 5th, 2004 09:25 PM
Whats wrong with this picture? chrisvonc Misc. Chit-Chat 3 April 8th, 2004 09:56 PM
