What year is my Defender 110? - Defender Source
Old June 6th, 2014, 10:27 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I've tried about 3 different resources to correctly identify my D110 to no avail.
All 3 give me 3 different results, so I am seeking the forum's help. FYI, the current US title identifies it as a 1986, but I'm not so sure anymore.
Here goes: SALLDHMV7BA263XXX
Thanks for the help.
Samer
Old June 6th, 2014, 10:33 PM
What did British motor heritage at Gaydon in England say?
Old June 6th, 2014, 10:41 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I did not contact them. I tried 2 different VIN decoders on the internet, and a factory LR parts manual. What I come up with is 1985, 1986 (currently titled as such in the US) and 1987 from the LR parts resource!!
It is a RHD, 5-speed manual, V8 3.5L carburator model.
Old June 6th, 2014, 10:45 PM
The "B" between the 7 and the A indicates year. The decode is 85-87my. The actual serial number where you put xxx is what will give the date. Email Gaydon and for 6quid they will give you the build date in an email.
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
H Wheel base: 110 inch
M Body type: 4-door station wagon (LWB)
V Engine type: 3.5 litre V8 petrol, carburettor
7 Steering and transmission: Right-hand drive (RHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
B Model year: 1985 to 1987
A Assembly location: Solihull, UK
263123 Serial number
Old June 7th, 2014, 01:29 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I have a 110 with "A" as the 10th digit of the vin but it's titled as an 86. I'm guessing it was manufactured in late 84 but not registered till 86 in the UK. Whatever the case, when it found its way to Ohio the DMV there determined it to be an 86 model from the then owners documents. I think most DMVs here are a little bewildered by a V5 document.
Old June 7th, 2014, 01:32 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Safe to assume then that:
A = 1985
B = 1986
C = 1987
Yes?
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old June 7th, 2014, 07:30 AM
Originally Posted by samer0214 View Post
Safe to assume then that: A = 1985 B = 1986 C = 1987 Yes?
Nope.
Decode a land rover vin using Calvin. If you don't know what that is try using google to find it.
Old June 7th, 2014, 07:38 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Already tried countless times at countless websites. Only gives a range of dates '85 to '87, and therein lies the problem.
Thank you - Samer
2003 Discovery II
Old June 7th, 2014, 08:44 AM
Bewildered ? A V5 document doesn't have any information about when a vehicle was built. It only lists a date of first registration, ie when Nigel and his bride drove it off the dealership lot. Most owners here could care less what year is on their title. My son's truck was obviously an 83 but was first registered in 85. We didn't care, but did go back and get a build date letter for his folio of records.
Old June 7th, 2014, 08:57 AM
These were very low production number vehicles with only about 7000-10,000 a year being built and breaks between model years were very fuzzy because annual model year changes common with most makes just didn't happen with the hand built defender like it did with the range rover etc. Rover didn't care much about VIN sequencing or even how many digits were in all the other manufacturers VIN's ie the recognized standard format @ the time, so it is what it is. Rover didn't change their VIN formats to conform with everyone else until they decided to sell the Range Rover into the US in 87 and were forced to. As advised above the only online resource to get an exact build date is the British Motor Heritage Museum @ Gaydon. For 6 pounds they will email you your exact build date usually the same business day. You can ask Land Rover for a letter but it has to be done in writing, takes a month and is considerably more expensive and comes by mail.
http://www.heritage-motor-centre.co....hive-services/
Old June 7th, 2014, 09:40 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thank you Douglas. I took your advice yesterday and already sent the inquiry to Gaydon. Can I PM you regarding this? My issue goes beyond just dating my D110.
Thank you - Samer
2003 Discovery II
110, defender, defender 110
First drive 110 after a year ArmyRover Misc. Chit-Chat 34 November 12th, 2013 05:33 PM
Need technical advice on this year/config 110 1of40 Defender Technical Discussions 8 May 18th, 2012 02:04 PM
Happy new year! a new defender! Skeena river rover Misc. Chit-Chat 1 December 31st, 2011 12:52 PM
Storing a 300 Tdi Defender for a year Chaucer Defender Technical Discussions 12 July 23rd, 2010 09:45 PM
One year with the 110 bjf Smaller Projects 88 April 12th, 2010 01:11 PM
