What would you do? - Page 6 - Defender Source
Old August 28th, 2014, 07:14 AM
Run it on a higher than normal antifreeze ratio ... That will give you extra cooling power.
My understanding is that it raises the boiling point, but lowers the cooling capacity. I don't know if this is true, but I've heard straight water would cool better than a mix. Obviously you wouldn't want to run straight water, but that's just what I've heard.
WW isn't designed to drop the temps-it elimates hot spots in the cylinder heads.
http://www.e30m3project.com/e30m3per...ter_wetter.htm
My co-worker started using it in his drag car and said engine temp lowered by about 10F. They can't use antifreeze on the drag strip.
Old August 28th, 2014, 07:28 AM
Originally Posted by Jymmiejamz View Post
My understanding is that it raises the boiling point, but lowers the cooling capacity. I don't know if this is true, but I've heard straight water would cool better than a mix. Obviously you wouldn't want to run straight water, but that's just what I've heard. My co-worker started using it in his drag car and said engine temp lowered by about 10F. They can't use antifreeze on the drag strip.
Jimmy you are right ... Adjusting the mix up to 70% anti freeze does raise the boiling point and does slightly lower the cooling capacity. However boiling over and losing all cooling capacity is going to kill the engine ...
If you could pick out a new winch bumper -- what would you pick? Dragon Breath Defender Technical Discussions 14 September 5th, 2013 02:27 PM
If you had your bulkhead out, what else would you do? aclarke Defender Technical Discussions 11 August 22nd, 2013 12:15 PM
If you were going install a gigantic amplifier in a D90, where would you mount it? Neil McCauley Defender Technical Discussions 11 November 19th, 2010 08:19 PM
Brake options - what would you do in a pinch? cgalpin Defender Technical Discussions 7 April 9th, 2008 08:20 AM
would you buy a '97 d-90 with 60k & no service rcd tomken Defender Technical Discussions 8 November 17th, 2003 08:01 PM
