What would cause this? - Defender Source
Old June 15th, 2012, 09:55 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Recently I noticed the cat was damp below the transfer box and the only wet spot was this threaded hole in the bottom of the case.
Today, while removing the oil pan, I noticed a dripping sound behind me and teams fluid started pouring out of the hole, running down the cat pipe and dripping all over the floor. What would cause this? I haven't even put any miles on it, just in and out of the shop.
Sent from my iPhone using D-90 Source
ID:	53056   Click image for larger version
Old June 15th, 2012, 10:57 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
R380, but that is actually the bottom of the transfer case, right above the Y in the Y-Pipe
Old June 15th, 2012, 11:38 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, I'll take some more tomorrow. I can't figure out what is causing it or where it's coming from.
Old June 15th, 2012, 11:59 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Rear output seal on the transmission? That'd be my guess if it's coming from between the transmission and t-case.
Old June 16th, 2012, 09:17 AM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Looks like transmission fluid not TC oil, for the color of it I mean.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old June 16th, 2012, 10:48 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It is trans fluid, but it's coming from the transfer case. Here are some more pics.
ID:	53070   Click image for larger version
Old June 16th, 2012, 11:16 AM
Looks pretty dry to me, did you remove the wading plug and 17 years of dripping transmission fluid come running out?
Old June 16th, 2012, 11:39 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, these are from the next morning. Not the best pictures, but it's hard to get a good one that's far enough back to see exactly where it is. I circled the hole it appears to be coming out of, but I don't know how or why it's coming from there. I'm suspecting the output seal as well, but what would make it just completely fail all of a sudden like that?
ID:	53076   Click image for larger version
ID:	53078   Click image for larger version
Old June 16th, 2012, 12:13 PM
Now that's a damn leak!
Old June 16th, 2012, 12:31 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Clean up the pipe too, the exhaust after the cat's will cause all that oil on the pipe to smoke like a big dog.
Old June 16th, 2012, 06:46 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, that's the weird part, the trans and t case have been out. If I remember correctly, all the seals were done, t case & tranny and the clutch is new. The leak seems to be coming from that boss. There is no fluid anywhere around it, just from that. My assumption is that threaded hole must go clear through to a cavity between the trans & t case. I just don't know what would cause such a catastrophic failure of the output seal.
