What would cause an inline fuse to Melt? - Defender Source
Old April 14th, 2007, 04:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
My rocklights stopped working. I just went to fix them and the problem is both the inline fuses (the plastic case around them), melted. Both fuses were fine, but they melted completely apart. What causes this? The wire guage is fine for the load. Everything is installed correctly too. Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 14th, 2007, 05:11 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I'd guess and say sounds like a heat source nearby. Wouldnt an electric spike pop the fuse before melting plastic? Are either fuses near something that would heat up that much (assuming on both sides of the truck?)? Is the wide casing one either side of the fuse melted too or just the fuse housing?
Could the fuse casing been bad somehow that the electricity was bypassing the fuse and generating heat rather than blowing the fuse? But I guess that should pop the light before it melts something right?
Chris von C
[/size]
Old April 14th, 2007, 07:52 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am pretty confused on this one. There is no external heat source that could do it. Both separate fuses did the same thing too. It could be a really bad fuse design, but something had to generate all that heat. The fuses were fine too. They were cheap lights, maybe they went too cheap on something.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 14th, 2007, 07:57 PM
chrisvonc's Avatar
chrisvonc
Chris von C
If the wire casing on either side of the fuse assembly is fine, I'd suspect the design too. Got a pic of where each is and whats around it?
Chris von C
[/size]
Old April 14th, 2007, 08:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
No, I didn't think to do that before I removed them. They are both mounted together with all the other wires that run into the firewall along with both my airlines. There is no other heat source where they were mounted. The plastic casing melted away completely so the wires just fell apart. Very odd.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 14th, 2007, 08:39 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I've read a number of instances of fuse holders melting, particularly those given in wiring kits for lighting. Not sure if it's poor wiring inside the holder, or a stupidly low melting temp for the plastic.
Were they the white plastic type that breaks in half to change the fuse? Never did care for them myself.
I've been using some of the Hella fuse holders for a number of projects. Good selection at rallylights.com and they use the ATO style blade fuses, with some multi-fuse boxes that hold 4, 6, 8, 12 or 16 fuses. The relay holders are pretty nice too, and many of them can dovetail together to make a nice solid unit.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 14th, 2007, 09:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yep,
They were to crappy white plastic that snap together with a half turn. Sounds like it might just be the design. I just wired them without the a fuse for the time being. I did the same thing with my hellas actually, and the time being ended up being 2 years and counting. But, I appreciate the info as I am going to rewire the entire truck next summer.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 14th, 2007, 11:54 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I've had many problems with that POS fuse holder design. NAPA sells replacement fuse holders that take the blade style fuses fot around $3.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old April 16th, 2007, 05:09 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Heat from flowing electricity... that's what melted 'em
The heat came from restisance in the fuse holder.... crappy connection, corroded contact or the like. It warns up poor plastic melts and there you go. The Headlight connectors in Discovery 1's do the same thing.
Built by accountants....
Mike Hammond
Old April 17th, 2007, 09:30 AM
epninety's Avatar
epninety
Dave Haynes
Ibex 240 2.8TGV
Fuses get hot when operated close to their current rating (otherwise they wouldn't blow when they exceed it). Poor quality fuseholders and undersized wire make the problem worse by not carrying the heat away, and by generating heat at bad connections.
- Depending on what you have already installed, consider a larger rating fuse.
- Change to a better fuse type (I like to ATO type as other have suggested)
- Uprate the wiring size - not because it's undersized, but because it will carry the heat away better.
- Make sure the connections are good (clean and apply petroleum jelly)
It's not uncommon to see ATO fuses where the plastic fuse body melts, due to operation close to current rating. Remember that a circuit with an 8A load *can* probably have a 10A fuse, but a 20A will usually give adequate protection (blowing before the wiring is damaged by a short).
All this assumes you don't have an undiscovered fault further downstream...
Old April 17th, 2007, 02:31 PM
mikeslandrover
Mike Hammond
Yep that summs it up
2.8 IBEX
Mike Hammond
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
A/C fuse jblieb Defender Technical Discussions 7 September 23rd, 2005 12:06 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
