get some one to help, the pump works well for me I just have someone man the hose thats going into the container while I pump the fluid into the the respective location. some of those pumps will screw into the containers. Why are you putting ATF in a 1995 Defender?
Jam a hose in the gearbox filler hole and run the other end up into the engine bay. You can pour the fluid in with a funnel that way and do it without spilling. I don't have luck with the pump either.
well for me untill I changed it out it just wasnt as smooth shifting, took longer for the syncros to get "up to speed" etc. etc. I changed up for some redline MTL and the difference was night and day
MTL OR SYNCROMAX!! LR has updated the the approved fluid for man boxes.
as for fluid transfer use a garden sprayer with a whip of hose at the end works very well anything else is messy
I use the single hose style transfer pump. Works like a giant syringe, but instead of a needle it has a flexible hose on the end. Put the hose in the bottle and pull the handle to suck in the fluid. Put the hose into the fill hole and push the handle to fill the gearbox. Got mine at Napa, was cheap too..... $20 or so IIRC.
Randy, I just clean out a 1 quart gear oil ottel, fill it with tranny fluid (redline MTL) and stick a clear tube on the end from home depot (only a few bucks). Stick the tube (only need a foot or so) in the tranns and hold the bottle up next to the tranns and squeeze. Only messy part is pooring the fluid into the gear oil bottle and if you are carefull thats not too messy either.
lol..that sux. almost as bad as me punching myself in the face when removing my steering wheel a few weeks back.. I used synthromax and my trans shifts a bit notchy into 2nd and 3rd and its new. unless you shift super slow.... I might try the MTL next... When should you change the syntetic stuff anyway?
I am breaking in a rebuilt transmission and tcase. Changed it at about 250 miles and will probably change it again at a 1000. After that probably once a year.
I'm sure the synthetic would last much much longer but you know it's my toy.
Rob Dassler rebuilt the gearbox and tcase and they work great. He also installed an underdrive and clutch for me. 100% satisfaction
Randy my syncros are fubared. It's only a matter of time before I rebuild. I change the fluid offten as the paint from the inside of the box is comming off & clogges the screen.
I don't know much about the r380
The lt has a removable screen under the large plug. mine gets clogged with a paint like flakes?
Randy these transmissions are not smooth imho lt's or r's.The r is a little better shifting than the lt77 again imho. None of these transes were made for bangin gears. [unless you need to!]
Does the R380 take the same quantity as the LT77? 2.2 liters ~ 2.3 quarts And does anyone know what size torx bit is needed to get the filler hole open?
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
