What wire gauge do i need for my spots? - Defender Source
Old February 6th, 2013, 09:57 PM
Need to order some hookup wire but don't know what gauge is required ..
Any suggestions?
Old February 6th, 2013, 09:58 PM
you should be fine with 14AWG for all aux lighting.
Mark Kellgren
KM4BOR
Old February 6th, 2013, 10:55 PM
Thanks!
Old February 6th, 2013, 11:04 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Any suggestions?
LED or halogen? How many?
Like Mark said you should be fine w/14 gauge but just figured I'd ask how many
Old February 7th, 2013, 08:39 AM
Halogen. 2 spots and 2 floods on separate circuits.
Old February 7th, 2013, 08:54 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
show up at my house and I will make you a harness and give you a PIAA relay set. I have spools of wire, shrink wrap, loom, etc...
Old February 7th, 2013, 09:09 AM
Jackie Treehorn
A
1985 (legitimately)
14 should be fine, but 12 costs pennies more so why not. I'd be more concerned with the quality of the casing/insulation.
Careful where you order/buy wire. I recently made the mistake of buying a bunch of 10/12/14 wire spools on Amazon and the quality sucks FWIW.
I've also adopted the practice of soldering virtually every connection (that don't need to be disconnected) and shrink-wrapping because of corrosion and sketchy grounds.
Good luck
Gas Gauge fried alaskajgg Defender Technical Discussions 0 April 4th, 2005 11:38 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
