what weight oil is best for diffs & x-fer case? - Defender Source
Old March 5th, 2004, 02:32 PM
JRowe
Jared Rowe
1994 D90. Stock.
I'll be replacing the gear lube in my differentials and trasfer case soon. I know there are different weights of oils that can be used. What are the best weights to use for each? (I live in California, so it doesn't get too cold.)
Old March 5th, 2004, 02:35 PM
90 WT unless you use Mobile One then your only choice is 75 which is still good. I use regular dino oil in the diffs as I have too change it allot due to water and mud. But I put Mobile One in the T-case.
Old March 5th, 2004, 03:32 PM
JRowe
Jared Rowe
1994 D90. Stock.
mobil 1 makes both 75w-90 and 75w-140. Is one bertter than the other?
Old March 5th, 2004, 04:01 PM
I have only seen the 75w-90, I have never seen or used the 140.
Check this out
http://www.robisonservice.com/servicedep/rover_tips.asp
Old March 5th, 2004, 04:06 PM
I use the mobil one hiowever i only have about 500 miles on it.
Old March 5th, 2004, 09:04 PM
AMSOIL 75-90. What else would I use, I sell the stuff!
diffs, fs, ht
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
