What Ujoint for early 110? - Defender Source
Old August 27th, 2012, 05:37 PM
Naplm00
Matthew
Well I am thinking i should rebuild my shafts as they are seeing a ton of use.
I have been reading that the Neapco 1-0005 is the correct shaft for all 90s and discos but that the Neapco 1-0153 is for 110s...
Can anyone confirm? I would prefer to use the 1-0005 due to the zerk placement
Old August 28th, 2012, 06:10 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Not again!
www.d-90.com/forum/showthread.php?t=26781
Take note, don't use the PDQ boxed 1-0153 (made in China). If using PDQ go with the 1-0154 (made in the US). If they are Neapco boxed either is fine (made in the US).
To be sure, measure your u-joints.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 28th, 2012, 07:12 AM
Naplm00
Matthew
Thanks that other thread is confusing as hell
Old August 28th, 2012, 10:51 AM
Antichrist's Avatar
Antichrist
Tom Rowe
From the other thread.
They are either:
1300 series
2.938" cap to cap and 1.063" cap dia
Precision 344
Neapco 1-0005
PDQ 1-0005
(the last 2 have the zerk in the end cap)
or
1310 series
3.219' cap to cap and 1.063" cap dia.
Spicer 5-153x
Precision 369
Neapco 1-0153
Neapco 1-0154
PDQ 1-0154
Precision 380
(the last 3 have the zerk in the end cap)
All of the above are made in the US.
Do not get the PDQ 1-0153 as it's made in China.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
'83 110 Ujoint steinhnj Defender Technical Discussions 9 September 8th, 2008 08:47 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
