What type of electrical connectors are these? - Defender Source
Old June 23rd, 2013, 07:18 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
The red an black male connectors that go in those holes? Hoping to wire a cig lighter outlet to charge my phone in an emergency.thx
Old June 23rd, 2013, 07:39 PM
jafir's Avatar
jafir
Jafir Elkurd
Are yours powered up? Mine are not. I figured they were connected to the 24v stuff that is all gone on my 90.
Also, I think I read somewhere about them not being fused.
Old June 23rd, 2013, 07:57 PM
josh-man's Avatar
josh-man
joshua
Hmmm. We're these all originally 24v converted to 12?
Old June 23rd, 2013, 07:58 PM
jafir's Avatar
jafir
Jafir Elkurd
They had a separate 24v generator. So they had all 12 volt stuff for normal vehicle operation stuff.
myoverlandrover's Avatar
myoverlandrover
josh
109
I'd just leave them alone and wire something like this in http://www.wunderlichamerica.com/mot...e/8600675.html for 23$. Found it by googling and happens to be for a bike but same thing.
Defender 110
It looks like the series ones and these should do. I doubt they are fused so beware.
http://www.vintagemotorspares.com/ph...ocument&part=5
Originally Posted by pendy
I'm here for the D's
Old June 23rd, 2013, 07:59 PM
The trucks have both 12 and 24 volts at the same time. Those should just be hooked to 12 iirc.
Old June 23rd, 2013, 08:36 PM
josh-man's Avatar
josh-man
joshua
That looks like a good alternative. Though I've never done any wiring but shit, happy to give it a go. Looks to have battery terminal connectors on it already too.
Maybe this is a better solution and would be wired correctly.
Thanks much
Old June 23rd, 2013, 08:52 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
Hey Josh-man, those sockets are for things like this;
http://www.ebay.co.uk/itm/Land-Rover...item2a2df912dc
They weren't originally fused, however a lot of military LR's were retrofitted with inline fuses on base, but there wasn't really any set place as to where that might be, so assume they aren't fused. They are also permanent live as far as I can recall. I personally wouldn't used them unless you put in a fused and switched socket on them. However, you will have a whole host of unused live feeds behind your military light switch console, some will be permanent live (brown wire I think) others will be ignition live (white wires) and some will be coloured wires for various systems that aren't fitted. Best bet is to get yourself a simple 12v tester to see which are live and which aren't, and if they are, then when. As far as sockets go, I love these; http://www.bluesea.com/products/1011...lt_Dash_Socket. I have two wired up in my MUD UK console.
Old June 23rd, 2013, 09:14 PM
josh-man's Avatar
josh-man
joshua
Hugely helpful MICHAEL. Thx!!
Old June 23rd, 2013, 10:37 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I had an air compressor in my old 88 that was wired for that type of plug. That light is cool.
1970 SIIA 88, Sold
Old June 24th, 2013, 02:55 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Those sockets were used for a leadlamp (and other 12v feeds, but mainly the leadlamp)
should be 12v, and as said, came from the factory UN-fused; there was indeed a modification done in workshop to add a fuse to it, as several LR's went up in flames!
You should be able to fit "banana" plugs to them, but there is a specific moulded 2 pin plug, as shown in the link above, to fit into them.
Old June 24th, 2013, 03:34 AM
Mine work, always hot 12 v. I pulled current from them and added a power outlet where the ammeter was in the dash.
Source for Electrical connectors leastonce Defender Technical Discussions 3 June 8th, 2010 03:39 PM
Help With Electrical Gremilins mdmccallum Defender Technical Discussions 8 January 7th, 2006 01:24 AM
Electrical problem whistler110 Defender Technical Discussions 10 December 12th, 2004 12:25 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
