what tool needed to remove shocks? - Defender Source
Old May 12th, 2009, 09:43 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
what tool do I need to hold shocks against rotation when unscrewing shocks?
TDI Guy's Avatar
TDI Guy
2015 LR4
a pipe wrench...
Legend in My Own Mind.
Old May 12th, 2009, 09:44 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
A strap wrench works well too.
Old May 12th, 2009, 10:34 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Cut off wheel on an angle grinder.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 12th, 2009, 11:32 PM
A giant set of channel locks works best.
Old May 13th, 2009, 08:41 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If their orginal in your area of the country, their probably rusted to the point that you'll need to cut them off. Impact wrench can take them off without need to grip them with a pipe wrench if they are not rusted and you need to preserve them.
Old May 13th, 2009, 08:53 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I was surprised to find that an impact wrench zipped the nut right off w/o the need to hold the shock with channel locks, etc. That was on the rear shocks but I imagine the fronts but be the same.
Old May 13th, 2009, 09:50 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
impact will work on front upper - problem is front lower where impact won't fit. There you can grab low on shock where it is not as weak
Old May 13th, 2009, 10:11 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Channel locks X2, and PB blaster!
Old May 13th, 2009, 12:41 PM
MAPP gas followed by liberal application of PB Blaster while hot. Then more MAPP gas, and more PB blaster. Then gently grip the shock with a pipe wrench or channel locks so as not to deform the tube. undo the nut as normal, it should come off ok. strap wrench is a great idea whoever suggested that. I even have one and never thought to use it.
Old May 13th, 2009, 03:36 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Stand back 20 feet and shoot a hole through the shocks with a 5.56 then you can stick a screw driver through it... If they're gas shocks stand back an extra 20 feet and use a bigger screwdriver.
Or use some channel locks.
Keith
Big, Red and ... aaa Red..
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
shocks cbkearney Defender Technical Discussions 21 January 3rd, 2007 08:40 PM
tool info needed Rover- Girl Defender Technical Discussions 3 March 31st, 2006 04:03 PM
How long do your shocks last? nickt Misc. Chit-Chat 10 March 19th, 2004 08:16 PM
