what to do with turn signals on 94 with tub bumper - Defender Source
Old September 20th, 2012, 12:58 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
Getting a tubular front bumper for my 94 D90. Was wandering what is usually done with turn signals?
Old September 20th, 2012, 01:12 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
maybe you can move them to the headlight bezel and switch to a 95-97 style lamp.
Old September 20th, 2012, 01:45 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There is a thread here detailing how to rewire the turn signal to the running lights
Old September 20th, 2012, 01:57 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Remove them and use the second running light. Very easy.
Someone else can chime in...but I even thing the plug is on the harness to do so (I found this out after I cut mine...)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old October 3rd, 2012, 08:15 PM
ditskovich's Avatar
ditskovich
dmitry
So I moved turn signals to running lights. Bulb 105 is too big for 1994 housing. And with original running light bulb it blinks too fast. Any ideas? Any shorter bulbs?
Old October 3rd, 2012, 09:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Doesn't answer your question but I changed the lower marker lights on my truck for a set of dual filament housings so I could still have running lights but also a turn signal utilizing 1157 (I think) bulbs.
Old October 3rd, 2012, 10:37 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I bought the plinths and lenses for a 95/97 when I installed my rockware bumper. I had to hole saw a new hole to fit the lense tail that holds the bulb. I also bought the headlight trim to match the 95/97. I modified the old turn signal wires to match the newer connector style. I had some "bonus" connectors on my harness and used them. But I think you can buy new style replacement connectors and they have the bullet connectors if you don't want to cut anything.
Old October 3rd, 2012, 11:38 PM
ditskovich's Avatar
ditskovich
dmitry
where do you get dual filament housing?
Old October 4th, 2012, 12:00 AM
CDeWan
Clay DeWan
5.3L beastie
Turned the lower running light into a turn signal...easy
Old October 4th, 2012, 08:07 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
As others are saying, the easiest way is to change the bottom running lights into the turn signals. That being said, I really like the look of the 4 running lights on the 94's and wanted to keep that look. I picked up some lights like these which are not stock for the 94 NAS trucks but are a close fit (a little trimming/massaging is necessary).
http://www.paddockspares.com/amr6513....html?___SID=U
I actually got them from Justin @ Lucky 8 rather than paying the shipping across the pond. To these I added a set of pigtails from AB (http://www.roverparts.com/Parts/8959ABP.cfm) to make wiring simple.
Unlike the stock 94 marker lights which are set up with a removable (marginally sealed) lens, these lights have a sealed front lens and the bulb/holder lock into the housing from the rear with a gasket. I wheel my truck as often as I can and enjoy water so I found that with the stock bulbs I was blowing them out often or filling them with water and mud. Since the change I have not had any problems. I am in the process now of doing the same modification to the top marker lights but will leave them as marker only but hope to gain the same water resistance
Old October 4th, 2012, 08:44 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The green and black wires heading off to the right are the wires to the 94' bumper mounted turn signal. Converting the lower marker light into a turn signal is as simple as unplugging the red and black wires from the marker light and plugging them into the same connector off the main wiring harness that you just removed the green and black wires from. They both use the same size barrel connectors. 5 minute job.
bumper, signal
Mantec Winch Bumper, what do you do about turn signals? Nine-Zero Defender Technical Discussions 1 September 9th, 2012 10:32 PM
Relocating bumper turn signals to the upper light housing paulb Smaller Projects 1 March 17th, 2007 10:50 AM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
