what to check next?! - Defender Source
Old June 22nd, 2005, 07:08 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I am trying to reason little things out as I go. The truck started to show it needed an O2 sensor with the change engine light going on and off and the code popping up 45. Then it started stalling at idle and running way to rich. The stepper is good. I replaced the plugs, the O2 sensors and it runs about the same. It will start and run like a dog and eventually idle up, but bogs everytime i take it out of gear on the road. TPS? oh, i just finished cleaning the throttle body to no avail. I just am doing what I can before i throw in the towel.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 22nd, 2005, 07:49 PM
Did you replace the distributor cap? Does the engine even have a distributor?
Old June 22nd, 2005, 10:12 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
it has a distributor. i am going to replace the fuel filter then go on to try the cap. It has to be one of a million little things.
1995 Defender ST
1996 Discovery SE7
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
