What the Heck is this Transmission Part? - Defender Source
Old June 11th, 2015, 10:41 PM
BlackField's Avatar
BlackField
Oscar
D110
Ok so I don't know much about the various transmissions in our trucks.
- I have a 5 speed.
- It's supposed to be an LT77
- I have a wobbly stick that the inter webs says will be fixed with a new bias plate and or springs or herbal viagra.
- I googled images and then went out to the garage.
Here's what I have. Doesn't look like what I was looking at on the web. Here's are my concerns:
Notice under the end of the spring leg there is a hole for a bolt. There was a bolt (20mm? M6) with a jam nut making the spring leg sit very high and allowing a lot of side to side wobble.
I want to just leave the left and right bolts out entirely, bringing the spring legs as low as possible and putting constant tension on the shifter. Like this:
This looks like its contributing to the wobbliness.
I took it apart and cleaned all the gunk out of it. Ill grab some GAA tomorrow, grease it and throw it back in the truck.
So is this an early version of the LT77 or something else entirely?
Oscar
Old June 11th, 2015, 11:12 PM
Edit: I was wrong. John is right, it's an LT77 or R380 shift lever housing.
Old June 11th, 2015, 11:25 PM
That is the Defender style shifter. Bias plates are on the Disco style.
It is missing the spring adjustment bolts. Look is the manual for instructions and pictures.
Old June 11th, 2015, 11:29 PM
See this video
Old June 12th, 2015, 12:03 AM
BlackField's Avatar
BlackField
Oscar
D110
Disco V. Defender got me again.
I removed the bolts for cleaning and was considering leaving them out in hopes of snugging the left right action a bit. I think this is likely a bandaid for the nylon, or whatever, ball socket the lower shifter ball slides into. I haven't checked yet but I'm guessing it's gone and that's where I'm getting the slop from.
What issues would leaving those bolts out cause (easier to mistake reverse and first)? It might make the shifter center a bit better while I'm waiting for a new socket thing.
Old June 12th, 2015, 02:41 PM
Shifter housing looks pretty worn out too. Has not seen a nice life.
I would grab a new one as well as the lever FRC7155 and FRC8724
Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Have a look under the housing and make sure the yoke for the selector is in good shape and it is tight to the selector shaft.
Old June 12th, 2015, 10:30 PM
BlackField's Avatar
BlackField
Oscar
D110
Thanks for the part numbers and the video John. The slick shift is going on my Xmas list.
I think I will order a new tower and gasket since I don't have one of those at all. The actual shift linkage was fine and so was the plastic socket piece.
I left the adjustment screws out entirely and it is much more... less sloppy.
Thanks again
part, transmission
WTB whatever the heck these are curry Wanted 8 January 4th, 2013 09:36 AM
Wiring harness Wht the heck are these CDeWan Defender Technical Discussions 5 December 5th, 2012 06:50 PM
Series Timing Questions What the heck bstraw Series Technical Discussions 3 June 27th, 2011 12:36 PM
What the fu....I mean heck lynchee Defender Technical Discussions 1 September 22nd, 2006 09:25 PM
Oh heck, Rust! mikeslandrover Misc. Chit-Chat 3 April 14th, 2005 01:28 PM
