What temp is too hot for these engines? - Defender Source
Old August 20th, 2011, 12:40 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
I've been running up to 210 at idle with the A/C (82 degrees outside temp) on, is this too hot? If not at what temp should I start to worry?
Thanks, VB
Old August 20th, 2011, 02:29 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Lots of opinions on this, but 225 is when I worry.
1963/2008 Defender Crew Cab
1965/1997 FJ45 Pick up
Old August 20th, 2011, 07:18 PM
When i get to 190 i start paying attention
Old August 20th, 2011, 08:13 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
What engine are we talking about?
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old August 20th, 2011, 08:54 PM
Verner Berry
Verner Berry
97 D90
Sorry, the 4.0
Old August 20th, 2011, 11:17 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
It's a bit warmer than usual, but not into the worry zone just yet. Wouldn't hurt to get it running cooler, but not hot enough that I'd be concerned.
It's around the 230 mark that people really start worrying, as that's when you start getting concerned about the sleeves slipping.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 22nd, 2011, 11:12 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Climbing this one stretch I go from an elevation of about 500-4,000 in less than 15 mins and my temps climb pretty fast too. This si a 4.0 with 100k and other than that it always runs at normal temps with/without the AC on. Once I'm at the top it cools down just fine and within a couple miles I'm back at operating temps again. Think running excessively hot for 10-15 mins is enough to cause perm damage?
Old August 22nd, 2011, 11:21 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
If you go over the 220 threshold from what I have read is when you might want to pucker. Aluminum engines do not like getting overly hot.
Old August 22nd, 2011, 12:11 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I build a cooling system to stabilize at 190 in the conditions you describe. Anything else is just rolling the dice waiting for an overheating event.
If you are spending your time staring at the temperature guage while you are adjusting the throttle then it is all a waste of time. IMO
legend in my own mind
Old August 22nd, 2011, 05:20 PM
jhhorse
joe heins
1995 defender 90
My understanding is conventional wisdom is modern engines (including the LR 3.9 and 4.0) operate most efficiently at 210 deg. F. So most cars recently built are designed to operate there with 210 deg thermostats.
This seems a bit warm but my 3.9 runs around town and highway at 190 and can get as high as 200ish climbing steep hills at 7000 ft elevation on really warm (95+) days. Cools back to 190 after. I don't think this is bad but I may be wrong
Old August 22nd, 2011, 06:33 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
At the risk of sounding like a noob, on my '94 gauge, with no actual numbers, what are the numeric equivalents to 1/2, 2/3, 3/4, etc?
I tried searching, but it looks like I need a Josh level of search acumen to find.
Old August 22nd, 2011, 08:53 PM
airbornrover
William Skidmore
SIII 109 SW
It is not very accurate. I changed out my temp gauge on the 94. The old only read in the middle and just short of overheat it will move into the red.
Old August 22nd, 2011, 09:45 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
A tick under middle is the sweet spot. Thats about 190. I think 3/4 is about 220-225. I'm not in my truck to see though. Also I would check your grounds to the engine. The Defender isn't grounded as well like the RRC or Disco is. And that can effect the reading. I recently put some better grounding wires in and helped with the "why did the temp jump a smidge when I turned my lights on" and "I hit that huge pothole and my temp jumped?"
Plus a new 5 core radiator helps too
Old August 22nd, 2011, 10:51 PM
jhhorse
joe heins
1995 defender 90
I would advocate a VDO gauge, my stock gauge would go just shy of the red and engine temp was 200. Just right of center was 180. VDO gauge installed, piece of mind.
Old August 23rd, 2011, 01:27 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
For the life of me, I cant find the post on "Why did the Temp Jump...." Someone have a link?
Old August 23rd, 2011, 02:49 PM
ini88's Avatar
ini88
Daniel Marcello
haha, oh that was my just paraphrasing things I've heard over the years. I don't think there is an actual thread on it.
engine
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Temp Gauge goes to hot on highway??? Help please! aircraftguy Defender Technical Discussions 8 May 25th, 2009 09:16 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
» Defender Registry
Broken
Z.G
Phoenix
Ovaltime
Add your Defender
