What spares do you bring on a rally? - Defender Source
Old August 9th, 2012, 05:21 PM
Nine-Zero's Avatar
Nine-Zero
Stephen Beres
Defender 90, 1994 NAS
I'm interested in knowing what you all carry with you on a rally, here's my list:
* Prop shaft U joints, front & rear
* Half shafts, all 4
* Hub Seals
* Wheel nuts
* Brake pads
* Diff, Tran, Oil Pan filler & drain plugs
* Serpentine, Water Pump, Power Steering belts
* Plugs, Wires, Cap, Roter
* Bulbs
* Fuses
* Wind screen wipers
* Paper air filter
* Oil filter
* Engine, Gear, Tran Oil
* Brake Fluid
* Coolant
* X-Treme Tape
* Bag of random bolts, nuts, washers, ext…
* Tools
Old August 9th, 2012, 05:23 PM
What kind of rally are you going to? Wipers? "Break" pads?
Old August 9th, 2012, 05:37 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Not sure why you need front u joints; if you're tearing up your truck and need replacement for those at a rally pull the driveshaft and leave it locked up (I carry enough to ensure a RWD truck)
Depending on terrain you should consider some spare brake lines for the front at least; I've had something reach in and snap one.
Fuel filter vice air filter (if your air filter is that dirty hit it with compressed air to clean it enough to get you home).
If you are going so far as to carry all four half shafts, might as well carry pre-greased bearings for a couple of ends too.
Don't forget the little stuff like jb weld, gasket maker, etc. You'll note that a lot of the big stuff you're carrying is going to cube you out quick on space and weigh a bunch.
r-
Ray
Old August 9th, 2012, 05:42 PM
Bottle opener
Duct tape
Trash bag
More beer
Old August 9th, 2012, 06:18 PM
I have a box with most failure parts including an entire ignition system (cap/plugs/wires/rotor/coil/ignition module/ECU/relays), alternator, water pump, drivetrain and steering crap if I think I will have an issue, always carry wheel bearings.
Old August 9th, 2012, 09:48 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
nine-zeros's cell phone number because u have spares for everything
Old August 9th, 2012, 09:58 PM
The Dro
Dro
1988 Ninety
Oil
Coolant
AAA Card
Old August 9th, 2012, 10:16 PM
How far you are going and who you are traveling with, and the kind of terrain you are dealing with are big factors in this decision. Add spare flip flops to your list
Originally Posted by pendy
I'm here for the D's
Old August 9th, 2012, 10:57 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Track rod. Having snapped one on a stump I can tell you that you're going Nowhere without a welder and some scrap metal. I carry one with the TREs already installed.
Old August 9th, 2012, 11:10 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
or long jumper cables and a #16 rod!!
Old August 9th, 2012, 11:14 PM
I generally carry Galpin & Huff, that usually covers my needs. Though ironically it was my winch used to straighten out Huff's tie rod last trip to Rausch so the tables were turned!
Old August 9th, 2012, 11:28 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Half shafts
Wheel bearings-prepacked
3 lengths brake line and fittings
A few spark plugs
Misc sensors
Thermostat
Serp belt
Tensioner Pulley
Coil pack
Fuel filter
Fuel pump-just the pump
Misc bolts
Drive member flanges
Ujoints
LHT and RHT tie rod ends
Upper and lower coolant hoses.
Power steering hoses
Old August 10th, 2012, 01:08 AM
Nine-Zero's Avatar
Nine-Zero
Stephen Beres
This is all good info guys, thanks.
I've recently relocated to California from rural Alberta up in Canada, it's interesting to see what folks carry in different parts of the country. Guess it's time to trade in my snow chains for sand ladders... Anyone interested in an auxiliary heater? I'll trade for an AC system ;-)
Old August 10th, 2012, 01:18 AM
Which aux heater?
Old August 10th, 2012, 01:21 AM
Nine-Zero's Avatar
Nine-Zero
Stephen Beres
The little guy under the passenger seat, it's a stock item on Canadian 90s. I think there's plugs on all the NAS harnesses for it, not sure. It was on my truck when I bought it.
Old August 10th, 2012, 01:29 AM
Perhaps we should chat. I'll pm you my email, can you send pics?
Old August 10th, 2012, 01:37 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Zip ties, duct tape, fuses, relays, cash, Amex
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old August 13th, 2012, 10:10 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Lift pump. Hose of various sizes. Hose clamps.
spare
anybody from CA going to the rally who could bring back some seats for me? tommyd Defender Technical Discussions 2 September 1st, 2008 06:11 PM
GBES GPS Rally June 16/17 Nevada MG/WCB Trips, Trails and Events 0 June 6th, 2006 07:28 PM
National Rally LEADVILLE 2005 mhansen Trips, Trails and Events 22 August 8th, 2005 09:10 AM
5000 Mile Expedition, Spares to take? h2eater Defender Technical Discussions 9 July 6th, 2004 02:14 PM
National Rally (1998) - Colorado USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 10:58 AM
