What size nut? - Defender Source
Old May 18th, 2006, 08:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
What size nut?
Hey guys,
What size wrench is needed to remove the nut on the bottom of the rear ball joint? Its the one on top-center of the axle. Thanks!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 18th, 2006, 09:18 PM
I've never been able to get a wrench in there to work it. I've just drifted the castelated nut off with repeated whacks.
Old May 18th, 2006, 09:27 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
30mm
Email:
Old May 19th, 2006, 07:12 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dave, did you get the boot I sent you for the ball joint?
Legend in My Own Mind.
Old May 19th, 2006, 08:44 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks guys!
Yes I got it, thanks! I am not sure it's going to work though, seems like it might be noo short?? Thats what I am going to do this weekend, along with reassemble the entire front end!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 21st, 2006, 12:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
A ring spanner works a treat. mostly they're 30mm but just to be difficult I had one on the 90 that was 26mm
And then a mighty whack with a lump hammer to release the taper
Mike Hammond
size of castle nut holding ball joint on rear upper triangle Noah Defender Technical Discussions 2 January 3rd, 2007 08:23 PM
front hub nut size? tkavan01 Defender Technical Discussions 11 May 22nd, 2006 06:06 PM
What size is the a-arm bolt? cbass Defender Technical Discussions 9 August 22nd, 2005 11:59 AM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
