What Shock for this rear mount? - Defender Source
Old June 24th, 2013, 06:13 PM
Slick62
Kevin
94 Defender 90
Hello
For Christmas my wife bought me a new set of Bilstein's shocks from Atlantic British, I just tried to install them this weekend and realized the prev owner had installed an aftermarket rear top shockmount, so the pin-eye shocks I have wont work and need an eye-eye shock.
So few questions
1) Does anybody recognize this shock mount?
2) What is a comparable Bilstein shock I can use?
3) Does anyone need a set of rear shocks that would fit a stock shock mount?
Thanks in advance
Kev
ID:	74920   Click image for larger version
Old June 24th, 2013, 06:22 PM
The Dro
Dro
1988 Ninety
Kev,
It's a Rockware.
You can buy the TF mounts or stock.
The rear shock top is eye-style.
Old June 24th, 2013, 06:58 PM
Slick62
Kevin
94 Defender 90
Thanks Mr Dro?
I see my issue there is a pin-eye converter on the bottom mount.
Not to be dirty but can I get a picture of your bottom mount, to see what its should look like
ID:	74924   Click image for larger version
Old June 24th, 2013, 07:56 PM
Remove the existing shock, remove the mount under the shock, and you'll be back to normal.
Old June 24th, 2013, 09:26 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Those mounts are for extended travel shocks. Did you get regular length shocks or extended?
Old June 24th, 2013, 09:36 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
You have what looks to be a Rockware shock mount painted yellow. Those took 14" shocks.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 24th, 2013, 09:42 PM
First question: what springs/lift are you running?
Old June 24th, 2013, 09:52 PM
The Dro
Dro
1988 Ninety
Originally Posted by Slick62 View Post
Thanks Mr Dro?
Mr Dro is my dad... You can call me Dro. . I've been called worse here.
You can easily remove the bottom eye-mount. That is where the shock stud mounts too.
If you are not planning to wheel that truck. Sell the RW mounts and get the TF ones.
Pedro
Old June 25th, 2013, 08:55 AM
The Dro
Dro
1988 Ninety
Kevin,
Here's a great page showing how it's done:
http://forums.lr4x4.com/index.php?showtopic=44704
Pedro
Old June 25th, 2013, 11:43 AM
Slick62
Kevin
94 Defender 90
Dro, thanks for you help, I think I am going to buy the Terra Firma mounts an go from there.
Old June 25th, 2013, 11:54 AM
The Dro
Dro
1988 Ninety
Sure thing
mount
rear upper shock mount thread Abrooks Defender Technical Discussions 2 January 10th, 2010 11:10 PM
Loop mount front shock tower? cellulararrest Defender Technical Discussions 19 March 17th, 2008 09:20 AM
Swing away rear tire mount DJG Wanted 0 December 7th, 2005 09:37 AM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
