what radiator is this? - Defender Source
Old April 8th, 2013, 02:08 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Can anyone identify this radiator? It has developed a bit of a leak and am weighing replacing versus re-coring but I can't find a replacement that looks the same. The motor is a Disco 200tdi.
I am leaning re-coring because I know this one fits, but have no idea what prices I'm looking at.
Thanks!
Old April 8th, 2013, 02:28 PM
God knows, but having the intercooler behind the radiator is a bad idea. It might be a V8 radiator with a horrible conversion job.
Old April 8th, 2013, 02:31 PM
I would guess it is a 4 cylinder 90/110 radiator (or whatever came in your truck originally).
Old April 8th, 2013, 02:48 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
You know, I always thought that the intercooler was in a questionable spot. I've seen a bunch of conversions done this way though.
The original was NA diesel, but can't match up one of those either.
Old April 8th, 2013, 02:53 PM
If it were me... I would get the proper 200TDI radiator. New, aftermarket is about the same cost as a good recore. You can then get the thing mounted better. I assume there is no oil cooler either?
Old April 8th, 2013, 03:05 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Oil cooler? Nope. Perhaps this is a good time to go back to the drawing board. I saw a 200 tdi radiator at RN that looked like it had oil line fittings...is that correct?
Old April 8th, 2013, 03:15 PM
I've not been involved in putting a 200TDI Disco into a Defender, so someone else that has, should chime in.
A good read: http://www.glencoyne.co.uk/tdiguide.htm
The important bit is this: "The Disco 200TDi uses the same radiator and intercooler as the Defender, but the frame is different.". Whoever did the swap should have moved over the radiator as well and simply modified the frame to suit. Maybe someone can help you find a used frame cheap to help.
Putting the oil cooler back in sure could not hurt.
radiator
