What Part Needs To Be Replaced Now?.... - Defender Source
Old August 29th, 2014, 04:58 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
While driving at a constant highway speed, with the a/c on, the air through the dash vents stops blowing. Fan is still running and air blows through the foot vents and wind screen. If I decelerate for a second, air comes back through the dash vents for a little while, then the cycle continues...
Can anyone tell me what part needs to be replaced and is it under the hood or do I need to take my dash or a/c box apart?
Thanks.
Old August 29th, 2014, 05:25 PM
I would suspect a small vacuum leak from the lines or the actuator is heading south. If you pull the grey panel with the vents you can see how it all works.
ac, part
Fuel Pump Replaced, now won't start. Kelbo Defender Technical Discussions 5 March 23rd, 2013 09:02 PM
Replaced passenger cat and now I get check engine light shawnpalmer Defender Technical Discussions 35 July 17th, 2008 10:14 AM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
Tdi proper startup after oil cooler lines replaced artm Defender Technical Discussions 5 August 7th, 2006 11:59 PM
Searching idle, replaced stepper now what? btate Defender Technical Discussions 3 July 15th, 2006 04:30 PM
