What part/kit do I need to fix this oil pump leak - Defender Source
Old January 23rd, 2011, 11:51 AM
This is a 3.9 from a 94/95 disco. Appears to be leaking from the hole with the circlip.
What part or kit do I need to fix this?
thanks,
charles
Originally Posted by pendy
I'm here for the D's
Old January 23rd, 2011, 12:30 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Should just need to match an O-ring up to the one that is leaking. It is a thin O-ring and metric if memory serves me right.
legend in my own mind
Old January 23rd, 2011, 07:17 PM
Thanks Jim!
I have an assorted set of O-rings so I'll open it up and find a good match.
Just wanted to make sure I didn't need to make yet another parts order. Seems every time I go to do something I realize I need more parts. Yesterday I realized I am missing the pilot bush so couldn't install the darn thing! Made a parts order yesterday, and then saw this today. Grr
Old January 23rd, 2011, 09:02 PM
budz
sal gorriceta
various rovers
Charles,
I think I have some o-rings that you need. Pm if you need one.
Sal
Old January 24th, 2011, 07:47 AM
is that a serp front cover? Whats up with that FRAM filter?
Old January 24th, 2011, 07:49 AM
Yes Serp belt setup is standard on discos of this vintage. That's the last filter used by the PO. Not getting replaced until the engine is in the truck.
Old January 24th, 2011, 10:03 AM
Naplm00
Matthew
in my old bmw, there was a spring loaded valve assembly behind the same type of cover plate on my oil filter housing...be careful when pulling that circlip out!
Old January 24th, 2011, 12:58 PM
I know of one instance where that clip failed and was potentially a disaster, you may have averted a similar incident fixing this.
Old January 24th, 2011, 01:12 PM
Sal, I sent you an email - it's indeed flat like Pendy said, and I don't have anything like it. Mine is hard and brittle (broke it when removing it).
There is/was a spring behind it, but I think because of the worn o-ring the cap was pressed against the side and didn't come out until I centered it.
Yes, I'm glad I noticed it Phillip!
Old January 24th, 2011, 05:27 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
That's the pressure relief valve. Why you got the cap/o-ring off you might as well pull the valve out and clean it real well and make sure it slides freely and reinstall. They like to stick and cause your oil pressure to do crazy stuff.
kit, part
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
