What other snorkel tops will fit a Mantec Snorkel? - Defender Source
Old April 25th, 2013, 06:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I would like to get rid of the mushroom style snorkel top on my Mantec snorkel. Has anyone attempted to fit a front facing snorkel top to the Mantec Snorkel? If so what did you get? Seems like there are very limited options due to the small diameter (70MM I believe) of the tube. Safari snorkel tops won't work due to the diameter. I have only found one and it is a no-name brand.
Old April 25th, 2013, 07:15 PM
Any 3" should work and they are pretty common. I have a 3" donaldson pre-cleaner on mine. There are actually a lot of choices out there. Look at forklift suppliers.
Mark Kellgren
KM4BOR
Old April 25th, 2013, 08:10 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I really like the Mushroom Style and may end up building my own Snorkel Setup. Let me know if you want to sell the top if you remove it. Sorry I'm no help on replacing it, but I think you have some good advice above.
Old April 26th, 2013, 09:47 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
If you do end up with a Safari style snorkel top, and it snows where you live, in the winter think about turning it around backwards. I had a few times (in my jeep with a snorkel) that ice/snow froze over the opening without me noticing... "why does it smell like gas and the engine won't start?"
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 26th, 2013, 09:57 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Donaldson top-spin...
http://www.donaldson.com/en/engine/s...ary/081343.pdf
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old April 28th, 2013, 09:08 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks everyone!
I could swear that when I measured, the diameter of the pipe is only 2.75" (70mm) in which case the options go down. Is there a chance that my snorkel is not Mantec?
Old April 28th, 2013, 09:11 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Any thoughts on experience with forward facing top versus mushroom top? I am mainly changing because the forward facing is smaller and I thought it would increase airflow, particularly at higher speeds (freeway driving).
Old April 28th, 2013, 09:13 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No problem if I end up switching.
Old July 3rd, 2013, 01:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mark.
How do you like the Donaldson? Is it a Top Spin HD? Does it increase the airflow and is it worth the cost? What snorkel make do you have? I think I have a Mantec and the OD is 75MM/2.95" so I assume you have the same? According to the Donaldson catalogue there's a 2.58" and a 3.07" version (ID). I assume the 3.07 will fit, with a gasket if necessary.
Old July 3rd, 2013, 03:12 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'm curious, is there a place online to order those Donaldson tops?
My brief search only came up a list of distributors.
Rent my
Old July 3rd, 2013, 03:16 PM
They sell adapters, so as long as the precleaner has a larger mount, it can fit. You need to make sure it is the correct flow range for your engine. Too small and you will kill power. Too large and it will do nothing.
Old July 3rd, 2013, 03:24 PM
maleger
Marc-Andre Leger
Keep in mind the Donaldson is plastic. Mine lasted a few months, until I hit branch in my driveway... not covered by warranty. Thjey can be purchased at truck shops.
I have upgraded to a steel product Centri precleaner. More money but more robust... You can find many sources online. I bought it on ebay.
Most important thing is to calculete the CFM requirements for your application. There is a formula: http://www.centriprecleaner.com/engineguide.html
Old July 4th, 2013, 07:05 AM
maleger
Marc-Andre Leger
3.07 is what I used with a 3" snorkel pipe (made from 3" exhaust pipe at a truck muffler place for a few hundred $s). With a stainless steel hose clip (from Traction truck stop store) it will squeeze into place and, once the clip is tight, be solidly held in place. for a different size you can try a rubber pipe fitting, which you can find in any plumbing supply shop.
The top spin is great for city driving, but will last only a few minutes off-road if there is flying pebbles or branches. Mine was destroyed by an old lilac tree in my backyard.
mantec, snorkel
Mantec Snorkel attachment UpnOver Defender Technical Discussions 7 December 8th, 2013 10:59 PM
Mantec Snorkel and Custom Plenum Install Jackie Treehorn Smaller Projects 1 February 11th, 2012 03:44 PM
Mantec Snorkel for TD5s...anyone? DiscoDino Defender Technical Discussions 1 June 5th, 2005 08:53 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
