What lift is this? - Defender Source
Old April 27th, 2015, 03:11 PM
snow686
1995 D90 SW
What lift is this?
This truck was done by the 4x4 center in VT. What size lift is this and tires? If it is over 33", does it really need new axles? They post all the work they did, but leave out the numbers on everything. Pretty good job though.
Old April 27th, 2015, 03:27 PM
Did you contact them?
Old April 27th, 2015, 03:50 PM
3 inches
Old April 28th, 2015, 08:09 AM
snow686
1995 D90 SW
3 inches
Okay, so does 3 inches mean new axles? and is their a kit that fixes drive shaft geometry and steering? And what do you think on those tires?
------ Follow up post added April 28th, 2015 08:10 AM ------
Yes i did contact them, very nice people but when asked said they do everything custom and I can bring my truck in for a quote.
Old April 28th, 2015, 08:12 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I think you may be confusing some different parts of the vehicle. What exactly are you looking for?
You should run heavy duty axles and diffs if you're really going to be working the truck off road with 33"+ tires, but it's not mandatory.
Lift has nothing to do with axles.
Anything below 3" really doesn't need that much extra work, especially if it's staying on the road.
Old April 28th, 2015, 08:31 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
FYI. These trucks can throw you a curveball every once in a while re geometry. A 2 inch lift on paper should not require any geo mods but sometimes you can find a truck that needs a DC front shaft to make things run smooth. 15 years ago I had a POE 90 with the same springs that I'm running today on my 97SW. The POE didn't need any mods and never had a single vibration. When I swapped the springs over to my 97 it vibrated from the jump between 30-55mph and needed a front DC to smooth things out. Clay
Old April 28th, 2015, 08:51 AM
snow686
1995 D90 SW
Primarily an off road truck, but I would like to be able to make the 4 hour drive to some of my favorite spots and still have a good rideon the ride there. I'm not trying to take the hardest path or rock climb. Just want to be able to get where I want to go, sometimes the path of least resistance is still unpassable in a stock vehicle. 2" is probably fine, was just curious what was done to that truck in particular to see if it is a feasible option.
Old April 28th, 2015, 09:26 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The company that built that truck won't tell you what springs and tires are on it? Seems odd.
Old April 28th, 2015, 09:32 AM
Some trucks need more work after a lift, other trucks need nothing.
Just because it looks good, doesn't necessarily mean you like the end result.
Looking at the build of that truck, I'm not sure whose suspension or shock set up they used. I ported over the Rovertym 3 inch from my D1 to my 90 and it rides like a leaf sprung truck
Hi-Lift Mounts milli For Sale - Parts 3 July 12th, 2004 02:39 AM
Hi-Lift jacks? xmod Misc. Chit-Chat 31 February 24th, 2004 07:31 PM
Hi-Lift or Jackall? wicks Defender Technical Discussions 3 January 29th, 2004 07:10 PM
High lift mount! TwisteD90 Misc. Chit-Chat 10 December 15th, 2003 02:35 PM
lift kit murph Defender Technical Discussions 19 November 19th, 2003 11:25 PM
