What kind of DC shafts and axles is GBR selling? - Defender Source
Old July 14th, 2005, 05:34 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Are the DC shafts that GBR sells their own make, or do they get them from someone else? i.e. Tom Woods or Six States?? I was just wondering if the price difference is because Bill is making a few extra dollars on a Tom Woods one (which isn't necessarily a bad thing) or if they really are different shafts.
Tom Woods retail price = $380
GBR Retail Price = $400
Also wondering about GBR axles too. Are they their own make, or do they get them from somewhere else? What is the difference between GBR axles and Rovertracks axles for instance?
Rovertracks = $400 (from the pics on their site, it looks like the flanges are part of the axle, is this true?)
GBR Rear axle kit w/ flanges = $599
Why such a big difference in price on the axles?
Discuss.
Thanks!
Old July 14th, 2005, 06:05 PM
GBR sells stuff MD axle shafts. The flange on the Rover tracks stuff is part of the shaft, I runnrover tracks rear axles on my 90 with a detroit, the diff will break way before the HD axle shafts!
Do you really want a DC driveshaft, or are you going with +3" of lift? I ran a stock shaft for almost 2 years with 35s and 3" springs, the UJs would need to be changed after a wheeling trip due to mud and and all, I replaced it with a custom shaft made localy for less then $300 and it's holding up rather well and runs 1310 Ujoints which you can get cheap from any autoparts stor as it is the most widely used UJ. Oh and the flanges on the new driveshaft aloow for twice the flex of the stock one.
Just my $.02
Old July 14th, 2005, 06:09 PM
cbass's Avatar
cbass
Bradlee Duncan
That's great stuff to know Mike, thanks. What do you mean "MD shafts"? I haven't heard of that before.
As for the DC driveshaft, I'm planning on RTE 3" springs, radius arms (corrected for a DC shaft), trailing links, and then planning on redrilling the swivels to correct the castor and get it back to a stock feel (only taller and flexier, hehe). I figure I might as well while the truck is apart. I know I could probably "get away" with a regular shaft for a while, but I would like to do it as good as I can get it.
Who made your DC for you? The only places that I know of around here that are reputable are Tom Woods and Six States. Both quoted me high $300's. Also, do you have the measurements and some of the technical info that you used to have them build you one? What did you do about the flange at the transfer case? Did they build the driveline to match that, or did you have to swap it out with a flange that matched the new driveline?
Old July 14th, 2005, 06:29 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
I was under the impression (from talking to Jesse at BWO) that GBR manufactured the axles themselves.
Old July 14th, 2005, 07:41 PM
I am pretty sure that they are Maxi-Drive (MD) stuff
http://www.4wdworld.com.au/products/maxidrive/index.htm
My Front shaft is stock. My rear driveshaft is not a DC, but it has better flanges that allow for more flex. The flange's are for an old Willy's or something and are the same as a Rover so no adapters are needed. I just went into the local driveshaft shop, told them the part # for the flange and said I want a shaft for the my defender. They measured my 90 and made one up all for about $280.
The Spicer Part number for the flange is 2-2-459, and they should be able to come up with the rest for a driveshaft. That Flange is good for 30*, while the stock Rover one is only good for 15*. And the way I see it, it's a ton cheaper to replace UJs when they get cruddy vs a DC.
Old July 14th, 2005, 09:30 PM
scoloco's Avatar
scoloco
'94 D90 ST
Nope. Bill does not make drive shafts. I'm pretty sure GBR sells maxi drives, so you are dealing with currency conversions from Aussie $. RoverTracks otoh source theirs 'locally' (as I recall).
Old July 14th, 2005, 10:24 PM
Rovertracks shafts are made by Moser. They are a made from 1541H.
GBR's 24 spline axles are made by Maxi-Drive. They are Hy-tuf (AMS-6418).
The M-D axles use a better material from an impact loading point of view. However, both should be strong enough (stronger than the ring and pinion).
Old July 15th, 2005, 01:24 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
John B. is correct about the axles
if you are looking for a DC, I have a LR one I can sell you off a disco II, in near new condition. I believe it needs an adapter for the flange which I can get too. The whole thing would be $200 +shipping (If you'll be at the Rally I can bring it). Let me know if your interested.
Old July 15th, 2005, 07:15 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile
It'd be nice to ask/hear both the vendors about this
P.S.
[John]
Heard from the "duck" recently?
As it seems he's vanished...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old July 15th, 2005, 04:37 PM
cbass's Avatar
cbass
Bradlee Duncan
Sheki,
I am interested, but I'm not too familiar with the D2 driveshaft so I have a few questions.
1) Is it pretty durable?
2) Why are you selling it?
3) If $200 includes the flange, let me know how much shipping is to 84097 and I might take it.
4) Do you have some pics of it?
5) Anybody else put a D2 shaft on the front of a D-90? Any problems with going this route?
You can PM me the answers or post.
Everybody,
Thanks for the info on the axles. It sounds like GBR has the best ones (if money were no option) but $200 more??? That's quite a bit more which I don't have. Sounds like that conversion rate must be kind of hard for bill to work with, eh? And it sounds like the Rovertracks ones can handle the job really well anyway.
Old July 18th, 2005, 02:54 PM
cbass's Avatar
cbass
Bradlee Duncan
BTW, I found out that GBR uses Six States made driveshafts. They're good ones. That's as much as I know so far.
Old July 18th, 2005, 03:19 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I installed a DII front DS on my DI. I purchased the adapter from Toddco Susp instead of a new flange.
I don't know if the front DS is the same length for the D90 but here are some pics of the spacer and the DS:
Pic1, Pic2, Pic3, Pic4, Pic5, Pic6
Of course the install was very easy using a Propshaft tool.
John C.
Old July 19th, 2005, 01:03 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Don't forget thatthe GBR Axles are waisted and the RT's are not, which also accounts for some of the price diff.
EwS
axle
GBR Rear Axles / Flanges road1will For Sale - Parts 1 October 10th, 2007 01:27 PM
Question on Axles bterpstra Defender Technical Discussions 43 November 13th, 2006 12:02 AM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
Misc- axles, BFG A/T's RRC Alloys, more Shane@EVS For Sale - Parts 1 January 19th, 2006 11:31 PM
