What is this electrical connector? - Defender Source
Old July 4th, 2008, 05:40 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Question What is this electrical connector?
I was under my 97 D90 and I noticed that there was an electrical connector dangling. The previous owner had recently replaced the 02 sensors and I'm hoping they didn't knock something else loose while doing that. The connector looks like it has been disconnected for a while but one would assume it should go somewhere.
Anyone know what it is? I can take another photo if this one doesn't do it. I'm holding the connector in the photo.
Hutch
Old July 4th, 2008, 06:16 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
What are the colors of the wires
Old July 4th, 2008, 06:45 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Hope the close up photo helps. The red striped wire looks gray/red but could be red/white but a tad dirty.
Old July 4th, 2008, 07:57 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Last question is concerning location of the connector. Inside engine compartment? Below where the two rear harnesses attach before going into the frame? I'll be over at the shop Sunday and can look thru my stuff to see if I can locate the red/white or red/gray wire.
Old July 4th, 2008, 08:08 PM
I have spent a lot of time under/in/with my Defender I cant tell where that is? A little help?
Old July 4th, 2008, 08:53 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
It is hanging just above where the exhaust from the 2 cats comes together to form the "Y" in the pipe. It's also right next to the little heat sheild. The photo is taken a few inches farther away - you can see the Y pipe and the connector along with other wires from the harness. Hope that helps - thanks for the help!
Hutch
Old July 5th, 2008, 04:44 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
One thing I should mention is that I noticed that when the differential is locked the diff lock light does NOT turn on. Could this be it?
Old July 5th, 2008, 11:11 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
http://www.defendersource.com/forum/...referrerid=917
Old July 6th, 2008, 09:10 AM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Perfect - thanks for the link. That has to be the same wire. I just need to find out where it goes now.
electrical
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
Trailer Light Connector loykd Defender Technical Discussions 3 November 17th, 2003 04:31 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
