What is this damn part? - Defender Source
Old November 21st, 2009, 01:32 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
See the metal underneath the SD ladder. Is that part of a jerry can holder? Or a swing-away tire mount? Something else? PO had no idea.
-Ren Ching
Old November 21st, 2009, 01:34 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Whatever it is it sure isn't stock.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old November 21st, 2009, 01:50 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Clearly it's the fremis holder.
Old November 21st, 2009, 01:51 PM
smob's Avatar
smob
Steve
Bought on Phlosten Paradise, probably.
-Ren Ching
Old November 21st, 2009, 02:27 PM
That is where you tie off your horse so he does not escape...
Old November 21st, 2009, 02:54 PM
I vote for either an old tire carrier or......a fremis holder
Old November 21st, 2009, 05:32 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
What ever it is, it needs a good wire brushing, sanding and coating ...
- Charles Eames
Old November 21st, 2009, 05:55 PM
Whatever it is ... it needs removing ... and storing ... because one day it might be needed!
Old November 21st, 2009, 06:43 PM
What the heck is a fremis?
Old November 21st, 2009, 07:30 PM
smob's Avatar
smob
Steve
It's the singular of "Fremen." From the sand planet Arrakis.
Ok, so, no one is helping me. Where is Ron?
-Ren Ching
Old November 21st, 2009, 08:42 PM
God knows what that is. Could be a kniffler-tube holder or a TR/ee deflector.
I would buy some new corner trim and toss that sucker.
Old November 21st, 2009, 08:46 PM
smob's Avatar
smob
Steve
Yeah, I'll probably do that. Just unsure if it was something interesting/worth retaining. I'll throw it in my "PO box," which has tons of stuff that may or may not be valuable now or down the road.
-Ren Ching
Old November 21st, 2009, 10:04 PM
Appears to be a hi-lift jack holder.
Ron
Old November 21st, 2009, 10:41 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
It doesn't matter what it is......what matters is that in needs to be galvanized !!!!
part
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
damn heater removal! alternative replacement? artm Defender Technical Discussions 7 October 15th, 2003 09:20 AM
