What Is This? - Defender Source
Old September 13th, 2011, 12:24 PM
provfirescott
1997 D90 SofTop White (SOLD)
What Is This?
Just bought a 1997 D90 softtop and it didnt come with a manual and cant find what this is its on the dash on the left hand side some type of switch
Old September 13th, 2011, 12:28 PM
auxilliary lights most likely
Old September 13th, 2011, 12:35 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Most likely the dimmer switch. Turn on the lights and flip the switch and see if your dash lights go out!
Old September 13th, 2011, 12:37 PM
Well yes the switch that is actually there is the dimmer switch...but the wire that used to be attached to a switch of some sort was likely wired to some aux lights.
Old September 13th, 2011, 12:47 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I'm not pick'n...just say'n what is supposed to be there. I think the wire goes to the butt vibrator!
Old September 13th, 2011, 12:48 PM
esprit99's Avatar
esprit99
Keith Imbriglio
1997 D90 SW Arles Blue
It is a two position switch for the dash lights. Center position is full bright. Push the top of the switch for position 2 and 50% dim.
Life is to short to drive ugly cars
'97 D90 SW #2251 Arles blue
'16 RRE
'04 Disco
Old September 13th, 2011, 12:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
Awesome!!! Seriously what the f*ck is going on with that wire?
Old September 13th, 2011, 01:02 PM
provfirescott
That wire is part of a key pad that is some type of security code to start and prevent start of car.I guess dealership I bought it from ripped it off the dash and left it hanging over the steering column
I dont have the code for that or the stereo!
Old September 13th, 2011, 01:14 PM
So you can't start the car or run your stereo? Hope you got a great deal on that thing. Where are you in MA?
Old September 13th, 2011, 01:21 PM
provfirescott
I can start car its not hooked up
I cannot turn on radio correct
Near Cape Cod
Old September 14th, 2011, 09:45 AM
Here is how mine looks for example. Switch on the right is for the Hella lights mounted on my bumper and linked into my brights so that when they're on, so are the Hellas (when this switch is enabled).
http://www.defendersource.com/forum/...4&postcount=34
Old September 14th, 2011, 09:52 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
There were 2 blank holes under the cover from factory. The only switch in there was the dimmer which you have. It is hard to notice it work. If you want you can tuck that switch up into the dash and put in 3 new 22mmx30mm rocker switches to control other things.
http://www.e-switch.com/Portals/0/as...medium/143.jpg
Old September 14th, 2011, 11:36 AM
provfirescott
ok great thank you
Still trying to get owners manual from dealership the guy who traded it in said he left it with all the codes written in and the window sticker
Seeing as its a one owner would be nice to have that stuff
Old September 14th, 2011, 12:01 PM
Dealer should have the radio code in the system.
Just show them a registration and they will probably give it to you.
