What is this . . . - Defender Source
Old September 9th, 2004, 07:53 AM
mlw911
Michael Walter
1995 D90 ST
What is this . . .
. . . plug that I must of knocked out/off while cleaning up the underside of my D90?
Old September 9th, 2004, 08:47 AM
mspell
Michael Spellman
That's your fetzer valve. I suggest you put it back in post-haste, you might end up burning the ball bearings if you don't.
...Just kidding, I'm afraid I don't know, could it be a drain plug for the body tub?
Old September 9th, 2004, 09:21 AM
artm
Arthur Maravelis
97 SW
Looks like an interior trim plug.
As a side note, I've knocked off the plastic seat lever thingy on the left side of the driver's seat when getting out. Crazy glued it back on and it's now tight. I suggest you guys check yours.
Old September 9th, 2004, 11:14 AM
draaronr's Avatar
draaronr
Here
LR3
Same thing happened to my seat lever knob, I had to glue it back on also. Works like a charm now.
Old September 9th, 2004, 12:38 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
That looks like the plug that belongs on the right side of your steering column.
DJ
Old September 9th, 2004, 12:46 PM
mlw911
Michael Walter
1995 D90 ST
Fetzer valve . . . I should have known (good one). Clue, it came off while scrounging around between the tranny and the seat boxes UNDERNEATH the car.
Thanks for the suggestions though.
Old September 9th, 2004, 01:00 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Michael
I understand you found it while UNDERNEATH the D90, but stranger things have happened. You also might want to check the plugs on both sides of the seatbox as well.
DJ
Old September 9th, 2004, 01:12 PM
How big is that fetzer valve? Is it made of rubber? I agree with DJ, looks like one of thoses little plugs on the steering colum or dash. There is not too much between the tranny and the seat boxes, just some wires, the speedo cable, break lines and the fuel line.
Old September 9th, 2004, 01:18 PM
mlw911
Michael Walter
1995 D90 ST
DJ - now that you mention it, there was a hole on the right side of the steering column. I put my aux lights switch there, you may be on to something. Now I have to figure out how it got under the car.
Old September 9th, 2004, 02:29 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Mike, the Fetzer valve is pretty big because it controls the discabobulator, but it is infact made of rubber.
Old September 9th, 2004, 03:24 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
if you don't need it anymore, let me know if you want to sell it. I lost mine and now I got this big hole on the steering column cover.
Old September 10th, 2004, 07:22 AM
mlw911
Michael Walter
1995 D90 ST
I don't know barry, these fezter valves are considered priceless in some parts of the world.
Old September 10th, 2004, 12:33 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Micheal
I was looking through my parts manual (for 93/94/95) and found a "plug" that looks very similar to the one you posted. It was located on the bulkhead right by the tranny tunnel on the passenger side. The plug in the diagram wasn't printed very well so I couldn't make a 100% postive id. If you'd like I can can the page in and send it to you? Let me know.
DJ
Old September 10th, 2004, 05:35 PM
mlw911
Michael Walter
1995 D90 ST
DJ - Thanks, that is exactly the spot where I originally found the plug lying underneath. I will crawl under this weekend and see if I can see anything. I have one of those cheapo ebay dvd manuals - let me check that first. Thanks for the help.
Old September 12th, 2004, 02:37 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Here you go Michael:
Old September 12th, 2004, 04:07 PM
mlw911
Michael Walter
1995 D90 ST
Awesome . . . thanks DJ!
Old September 12th, 2004, 06:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That is the plug that goes on the right hand side of the steering column, opposite the starter switch (the switch is on the left, this plug is on the right)
Old September 13th, 2004, 01:13 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
No Problem Michael! Glad I could help.
