What is the Inertia Switch for? - Defender Source
Old December 19th, 2004, 08:00 PM
Mark M
Mark Mathews
'94 Beluga Black ST
While looking for the brown module to reset the service engine light I came across an inertia switch mounted behind the fuse box. Does anyone know what it is for? On a different note, in a '94 the reset module is located behind the instrument cluster, not behind the fuse block as the FAQ suggested.
Thanks.
-Mark
Old December 19th, 2004, 08:06 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
It **should** cut off the flow of fuel in the event of an accident. (safety feature)
I bought the diamonds myself so I would not have to say thank you to anyone.
Old December 19th, 2004, 08:31 PM
Melissa hit the nail on the head, When your rover gets bumped it shuts off the gas. If you bang your dash hard enough it will pop, and you can reset it by simply pushing the button back in. And yep the reset module is behind the dash on 94's.
Old December 20th, 2004, 12:03 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Anyone know where the inertia switch is on a '95 D?
Old December 20th, 2004, 02:36 PM
I thought it was a button you hit when you got into a bind while offroad??
Old December 20th, 2004, 02:58 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
I hit a set of tracks too hard one day in the Disco...enough said.
Old December 20th, 2004, 04:24 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I assume it should be fairly close to the location as it was in my 99 D1 which was on the left side of the rear firewall in the engine bay. That damn thing used to trip on me all the time.
Chris von C
[/size]
Old December 20th, 2004, 05:51 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
It is on the drivers side of the firewall in the engine compartment.
Old December 21st, 2004, 10:58 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Can you describe it, does it have a reset button?
Old December 21st, 2004, 11:06 AM
Looks like a kinda relay but it has a little button on top.
switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
94 with AC- how to get to the inertia switch ? Doug Crowther Defender Technical Discussions 3 September 8th, 2006 03:11 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
