What is the best gearlube to use in Trans - Defender Source
Old December 31st, 2008, 02:41 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have a Lt85 making a bit of bearing noise, output shaft so it seems...everything accept 4th gear is making a bit of noise.
I was thinking about adding AMSOIL or Mobile One.......
Anybody have a suggestion of which one is better or a better one altogether to use??
Old December 31st, 2008, 03:42 PM
Redline MTL SEARCH. As far as your issues may help but only a bandaid.
Old December 31st, 2008, 04:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have used royal purple.. syncromax I believe its called
Legend in My Own Mind.
Old December 31st, 2008, 04:24 PM
MTL is better. I have one full container of that Royal Purple if anyone wants it, shipping + 6pack funds and its yours. I tried the RP I ran it for a couple months went back to the Redline MTL.
Old December 31st, 2008, 05:27 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I had not considered those, even though I have heard of them. Redline is very good stuff & Royal Purple I have only used there oil so I cant comment for trans fluid.
Old December 31st, 2008, 05:44 PM
Grover's Avatar
Grover
Thumbs up
The day I bought my D90 I replaced all drivetrain fuilds with Mobil One synthetics. No problems thus far...
Cheers...
Old December 31st, 2008, 08:06 PM
What did you put in the gearbox?
Old December 31st, 2008, 09:45 PM
Mike, read this thread from disco web on oils. Mobil 1 synthetic is apparently not a good choice.
http://www.discoweb.org/forums/showt...ght=oil+weight
I recently switched to rotella myself - happy so far.
charles
Old December 31st, 2008, 10:20 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I have a LT85 in my truck too and it is a rougher louder tranny than other. When I first got my truck the shifting was a little rough and a little noisy, I replaced it with Redline MTL. It's a litt;e pricey but it made a big difference in noise and rough shifting. Shifting is much easier with Redline. I have talked with other LT85 owners and they told me Mobile one did not help with rough shifting or with noise.
Go with Redline.
Remember it's a LT85 and it will never be as smooth as other Land Rover transmissions but if you can put up with that you gain a very stout transmission.
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
tough trans ? boxerhips Defender Technical Discussions 11 June 20th, 2004 11:52 PM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 10:32 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
