What is that infernal clicking? - Defender Source
Old February 15th, 2013, 07:54 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
So my beloved '97 NAS D90 SW has developed an interesting tic. Or, that is to say... click.
It's a relay switch. Of that, I'm sure. It togges on and off. Then on. Then off. Usually a second or two between clicks. Then stops for a minute or two. Then does it some more.
Odd.
The sound is coming from the passenger footwell (from under the A/C unit, I think) and it's notable louder than blinkers relay.
Any guesses? Seems to happen when the truck warms up, on the highway, when I can't get to it to figure out where it's coming from.
Old February 15th, 2013, 09:31 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Amazing, Josh's started doing the same thing, we were just talking about it.
Old February 16th, 2013, 11:12 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I had the same thing. Mine sounded like it was coming from the a/c in the passenger footwell.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old February 16th, 2013, 12:01 PM
navydevildoc
Neill Thornton
If it's like Josh's, it is clearly electrical in nature, as soon as you turn on the ignition it starts, and it sounds like a relay. Very regular timing, it wasn't erratic at all.
It's not a rattle or squeak kind of thing.
Old February 16th, 2013, 12:50 PM
carlosz's Avatar
carlosz
Carlos
it could be the a/c cycling on and off during use of the hevac in order to dry the cabin air...
Old February 17th, 2013, 01:55 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Have you tried to pull the AC fuse to see if it stops?
Negative. I have no idea where to begin so this is just as good a place as any.
Old February 18th, 2013, 06:59 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
New info. When it's clicking it has zero impact on AC function.
Also... whatever that relay switch might be, it always clicks on when I turn the key in the ignition. Not when I engage the starter, when I turn the key from off to the half-way position when all the dash lights power up.
Old February 19th, 2013, 12:27 AM
navydevildoc
Neill Thornton
You need to start pulling fuses and note when it stops. Then we can trace the wiring diagram to the offending part.
Old February 19th, 2013, 05:29 AM
How about pulling the relays one by one?
Old March 15th, 2013, 05:47 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Resolution:
It was the relay closest to the firewall on the outside edge of the A/C unit (Passenger side). Turns out the cooling fan (Part # STC3969G) controlled by that relay had seized up.
Clicking in tranny when downshifting from 5th to 4th DonFromWhitby Defender Technical Discussions 5 October 1st, 2009 02:46 AM
Relay clicking, engine stuttering.... help! revtor Defender Technical Discussions 9 December 6th, 2007 08:23 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
Clicking from the dash? greg_sikes Defender Technical Discussions 14 November 9th, 2003 07:31 PM
