What is biggest tire size I can get on stock rims? - Defender Source
Old November 15th, 2009, 04:34 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
I have stock alloy rims and want to go to a 12.5" x 33" tire. Will the rims accomodate these tires?
Thanks in advance for any help.
Old November 15th, 2009, 05:02 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yes.
Old November 15th, 2009, 10:12 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
a 12.5 inches wide tire on a 7 inches wide rim, hmmmm, not sure about that.
- Charles Eames
Old November 16th, 2009, 12:27 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yes, I have 305/70R16 BFG's on NAS 110 Steel wheels right now. I think you're going to need spacers though.
Old November 16th, 2009, 07:18 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Actually a 12.5" is a 317 mm wide tire.
Damn, a 305 on a steelie , i get nervous
putting a 285 on 7" rim ...
Anyway, if it works for you .
- Charles Eames
Old November 16th, 2009, 11:21 AM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
I have 285/75/16's (33" OD Good year MTR's) on stock Alloys with no lift, and they look great - but they do rub on extreme turns.. Otherwise, only an issue when parking... but GREAT offroad.
Old November 16th, 2009, 12:09 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
12.5 wide with no problem.... you will need to run spacers though
Legend in My Own Mind.
Old November 16th, 2009, 02:48 PM
Abeer's Avatar
Abeer
Amarveer
94 D90 ST
Don, you have any pics of your car/tires to share?
Old November 16th, 2009, 05:03 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Believe me, I was skeptical at first as well. I couldn't decide between the 285 and 305, but Mike at ECR said I won't have any problems and you can put any width on the NAS Steelies, so I took his word on it and I've been very happy so far. It was a bit of a PITA mounting the tires, but I'm happy with them and everyone who sees it likes the look...
Old November 21st, 2009, 10:19 AM
Rugbier's Avatar
Rugbier
Gustavo
Chris' D90 has Spacer ( 30mm ) and he is running 255/85 ( already 33 ), but I will be so nerved up when airing down with that width
NO SIGNATURE
Old November 21st, 2009, 11:09 PM
cdb
Clark Bowen
I just swapped 35" X 12.5" Nitto Grapplers from stock alloys to 8" Pro Comp alloys and the tire shop said they had the worst time getting the tires off the stock alloys because of the RR inner bead and the Pro Comps were a piece of cake. That says to me I probably just increased the chance I'll pop a bead, but at least I got rid of those damn spacers.
2011 RR HSE -
2001 GMC 2500 4wd
rims, tire
35" on Stock Rear Tire Carrier saber6 Misc. Chit-Chat 4 November 16th, 2005 09:45 AM
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
4 - 285/75/16's on stock D90 rims, 98% new, also spare & carrier januconn92 For Sale - Parts 7 October 13th, 2004 10:31 AM
opion needed on selling my stock rims. januconn92 Misc. Chit-Chat 2 September 26th, 2004 09:19 PM
